Previous in Forum: Transmission Line Services   Next in Forum: Cable Meggar Values
Why Do Earthing Plates and Electrodes Corrode?
02/12/2010 8:34 AM
Earthing is a criticle issue worldwide. I tried so all type of earthings like plate type, pipe type and electrode type, chemical type & gel filled type but within four to five year all get corroded and earth resistance found more than 100 Ohms.
I tried to develope a unique product which must not get corrode please give me suggest on the subject.
Raju
Earthing is important but neglected
Good Answers: 42
Re: Why Earthing plate or electrodes get corrodes?
02/12/2010 11:15 AM
Moisture , oxygen, ions present in air, salt and water ,chemically react with metals solubilizing them as oxides, hydroxides, sulphates, chlorides etc leading to dissolution of the solid metal surfaces.
How about trying a vacuum sealed earthing system?
Encapsulation, Nano technology etc should have better solutions to your quest.
Nature is so graceful and naked. Human possession is ridiculous.
Re: Why Do Earthing Plates and Electrodes Corrode?
02/12/2010 7:00 PM
Why don't you invent Palladium.
02/12/2010 10:46 PM
No, naquadria is the best for this application.
Good Answers: 56
02/13/2010 12:04 AM
If it's a galvanic reaction that is causing the damage then you may want to consider adding an additional ground to the system using a buried sacrificial zinc plug.
Zinc's location on the galvanic scale make it the ideal material for protecting expensive propellers, rudders and drive shafts on boats, especially those in salt water.
Inexpensive sacrificial zinc pieces designed for just this application, can be found at most marine supply distributors.
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
02/14/2010 8:11 PM
Have you considered stainless steel for the electrode? In some areas where the soil is very dry, multiple bonded electrodes must be used to achieve low resistance.Earth ground carries very little current.The neutral conductor carries most unbalanced current of the system.Chemicals may be used to enhance conductivity of the electrode.If using SS electrode, do not apply chemicals for a few days after driving in rod.This allows the Chromium Oxide surface of the electrode to heal and provide corrosion protection.A freshly scratched SS electrode will corrode if exposed to corrosive chemicals before "healing" has occured on the surface.
Anonymous Poster (1); Laughing Jaguar (1); lyn (1); Mikerho (1); s.udhayamarthandan (1)
