Previous in Forum: Hydraulic pumps.   Next in Forum: air condition project
Cooling Tower Needed
02/13/2010 1:07 AM
I am looking for a cooling tower or centrally airconditioning plant for a 7 storied building of approx 30000 sqft area can I know the companies doing this type of Job the construction is to commence in March so I can do other provisions of ducting etc for each floor
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: Mr
02/13/2010 6:03 AM
I select and specify Cooling Tower Systems, Inc. The tower is sized for your refrigeration plant's heat rejection calculations. These towers can be assembled on site. If you have a freight elevator that rises close to the roof level, you may be able to avoid the cost of cranes or helicopters lifting the tower into place. They are available in multiple sizes.
http://www.coolingtowersystems.com/index.html
"Memorize the calculations, you look like a fool searching your notes while teaching class"
Re: Cooling Tower Needed
02/14/2010 7:22 AM
I design, specify and install mechanical systems in addition to all other major building systems (Architectural, Structural, Electrical, Plumbing, Fire Protection, Process). Take a look at our subject matter expertise, www.ipsdb.com.
02/15/2010 3:38 AM
If the project is to be carried out in India there are few reputed air conditioning contractors like Voltas, Blue Star etc. You can contact them for any type of technical assistances. For cooling tower supplier if you refer the yellow pages of the telephone directory you will get list of suppliers.
10/07/2024 9:01 AM
Are internet search engines not available at that location?
Register to Reply 4 comments
jcchiefeng (1); mrswamy (1); PBucklen (1); PWSlack (1)
