Previous in Forum: Ski jump distance enhancement   Next in Forum: No communication with Rotor Packer Machine
PLAN FOR IONISATION CIRCUIT FOR COPPER IONS
02/13/2010 4:48 AM
I am in need of a plan diagram to connect a circuit to make copper ions for a swimming pool. I want to use it in conjunction with regular chlorine for disinfection. Pls help
Pathfinder Tags: cooper ion
Good Answers: 146
Re: PLAN FOR IONISATION CIRCUIT FOR COPPER IONS
02/13/2010 8:43 AM
Just an aside - I hope you look into the health effects of your plan. Copper is toxic and copper sensitivity is quite common. Exposure can increase the risk of becoming allergic and having reactions to small amounts.
I for one would not swim in a pool disinfected with copper ions.
incus opella
02/14/2010 10:03 AM
Hi, Thank you for raising your concern. I have checked the web and see that copper is much less toxic than presnely susing chlorine. Article from web FAQ :
Q: Is Copper in the water safe for me?
A: Absolutely. We run our pools at the safe drinking water level according to the EPA. In fact, if
you drank 2 gallons of pool water, you would ingest the amount of copper found in a multiple-
vitamin.
Q: How does the ECOsmarte System work?
A: Simple. Every time your pump runs, the ECOsmarte oxygen electrodes deliver a non-chemical
shock to your water when the water passes through your pressure line. Once per week you test
your pH and copper levels. You will switch the button on your Electronic Control Unit and ionize
for 4 - 8 hours depending on your pool size and bather load. This will put copper in your pool
which is a great algaecide and deadly to viruses.
Q: Is the system easy to install and operate?
A: Yes. As mentioned in the installation and operation sections on our pool and spa products,
installation of the Standard and Turbo models can easily be completed in 30 minutes. Operation
of the system requires weekly testing of the pH and copper in the pool water and simply flipping a
switch, much like a light switch on and off a couple of times.
Q: How long do the copper bars last and how much do they cost to replace?
A: Life of the copper bars will depend on the length of your pool season, the calcium hardness of
the water and the size of your pool. Normally, they will last 3-5 years and cost only $95 to
replace. They can be replaced by the pool or spa owner with a screw driver.
Q: How does the ECOsmarte compare to salt-to-chlorine generating devices?
A: The ECOsmarte system is superior to salt-to-chlorine generators in many ways. First, pool
water treated with the ECOsmarte system is preferred by virtually every person that has had the
opportunity to swim in a pool treated with ECOsmarte versus a pool treated with a salt-to-chlorine
generator. Secondly, water in an ECOsmarte treated pool is free of all sanitizing
chemicals and has the feel and taste of bottled water. Salt-to-chlorine generators produce
chlorine and can adversely affect pool equipment, liners, covers and the swimmers. The
discharge water from a pool treated with a salt-to-chlorine generator can contaminate soil and
ultimately kill vegetation and sterilize the soil. For a complete list of comparisons between
ECOsmarte systems and salt-to-chlorine generators click here.
Q: My pool man says this will not work. What should I do?
A: Would you ask him which pool he knows of where the ECOsmarte System did not work?
Chances are that he is not familiar with the ECOsmarte system or has confused ECOsmarte with
another alternative system. All of our equipment comes with a 60-day money-back guarantee.
We would be interested in the name of the unsatisfied customer. We get very few returns and
provide technical support for all of our customers through our toll-free support line: 1-800-ION-
SWIM.
Q: If I have other questions about the system, who can I call to discuss the
system in more detail?
A: You can call us at (866) 246-3546 and we will gladly answer any questions you may have.
Q: How much savings will there be?
A: If you currently use any chemicals for sanitizing, algae control or clarifying your water, you will
no longer need them. If you are currently running your pump more than 8-12 hours per day, you
will save electricity. If you currently need to backwash more frequently than twice a month, you
will likely save water. The actual savings amount will very depending on the size of the pool, the
type of sanitation currently being used, the length of the season and other factors too numerous
to list here.
While the system will easily pay for itself in a few years, money is only one of the reasons a pool
or spa owner should buy an ECOsmarte system. The health and safety issues are equally if not
more important than the economics of owning the system.
Q: Will the copper stain my pool?
A: The amount of copper being added to your pool is significantly less than would begin to cause
staining.
Q: If the ECOsmarte is such a good system, why haven't I heard of them
before?
A: ECOsmarte has been installing pool and spa water purification systems for over 10 years.
They have over 10,000 installations worldwide. Until the last few years, they have marketed their
products only over the internet. In the past few years they have begun building a worldwide
network of distributors, dealers and resellers. They currently have over seventy dealers in North
America and the network is growing every year.
Good Answers: 146
02/14/2010 12:51 PM
It does sound good, and it's nice that the person selling this is so reassuring about all issues including safety, efficacy, and the doubts of your "pool man". (call me pool man)
Since the virucidal and other expected benefits vs. the hypothetical risk of toxicity is entirely dependent on the concentration of copper, the buyer is well advised to test the water for copper levels to see if the concentration ppm is at the desired level for both safety and efficacy. Search and you will find, ppm concentrations necessary for virucide, bactericide, algaecidal effects you're hoping for - your required minimum. And human toxicity ppm and allergenicity ppm is also presumably well known. Get the figures and compare your test results, before the "60 day warranty" is up.
For a filtering system as described, flow rate, retention rate, size of the filter, pool volume, are variables that will affect the results. Is the product well engineered for the purpose? Maybe there's more detail in the manual. Good luck!
incus opella
Good Answers: 101
02/13/2010 7:35 PM
It's simply a DC circuit with copper terminals similar to what is used for electrolysis. However, please note that while copper is a very effective disinfectant, it's generally not a good idea to come into physical contact with both electricity & water at the same time; it can be a truly shocking experience.
02/14/2010 10:06 AM
Hi, Thanks for your comments. I will put the copper ionisation system near the pool pump and filter, away from the pool, the voltage required is very small and DC. Hope it will work? Thx
artsmith (2); DVader1000 (1); Rahim (2)
