Previous in Forum: PLAN FOR IONISATION CIRCUIT FOR COPPER IONS   Next in Forum: Auto Propelled National Reciclying Financial Wheel
No communication with Rotor Packer Machine
02/13/2010 12:44 PM
I changed the I/O card in my system, the problem now is that it does not communicate with the Rotor Packer machine.
What could be wrong and what should I do.
Paschal from Port Harcourt South- south Nigeria
Re: No communication with Rotor Packer Machine
02/13/2010 3:17 PM
Oh Brotherrrrrr! What can I say. Probably the contacts are somewhere loose or dirty. Check for full operational voltage input and be careful with your grounds connections as well. Watch for any static charge spark during replacement operation hopefuly is not the case as static charges sometimes migth harm the board somehow, look out! Also try unplug for few minutes and plug it back again and try reboot it is neccesaraly after that. Check for any other sensor misalignment or dust covered reflector. Check if any microswitch are in the wrong (NC/NO) position as well just in case. That will do. Allset then, back on business!
Lock &Tag,
MC
02/13/2010 10:03 PM
You may need to do some programming on the new I/O card, or in the main controller, such as "telling" each what addresses to recognize. Or set some DIP switches. I apologize for the vagueness of this, but there are many combinations of controllers and I/O interfaces, of which I know few.
02/14/2010 2:32 PM
Why did you change it? Is this the I/O card in the machine or in the computer/controller? Is the new one identical to the old one? Does it use the same cables/connections? What method of communication (RS232, RS485, Ethernet, Bluetooth, etc.) Have the settings been made identical to the original? etc...
We need LOTS more info.
