Previous in Forum: selection of flange material   Next in Forum: Cantilever beam deflection.
pneumatic cylinder use
02/13/2010 8:26 AM
hi, i am working in a factory as designer for jigs, fixtures, gauges and small automations. i am in tension from many days for how to use pneumatic cylinder for an object to hold it. if any formulaes are available so, please give me.
Mohammad Irfan
Pathfinder Tags: pneumatic
Re: pneumatic cylinder use
02/13/2010 9:36 AM
Will you use the cylinder to hold an object in place, by extending the piston?
02/13/2010 10:43 PM
Sir,
I am using the pneumatic cylinder to clamp an object while the operations occurs,
If you are not understanding my question then i will send to you a drawing for this question.
Thanking you
Mohammad irfan
02/14/2010 4:52 AM
There are two ports on most cylinders. Apply air to one port, the piston deploys. Apply air to the other port, piston retracts.
This is so straight forward that I can't think of anything else to add. It's up to you to design the part nest/holder.
I'm not aware of any formulas for this.
02/13/2010 11:16 AM
can you explain the question in better way?
02/13/2010 3:10 PM
Congratulations. You must be a true genius. How did you ever wangle a job as a tool designer?
02/13/2010 9:00 PM
Fluid Power Basics
Practical knowledge about hydraulic and pneumatic components and systems
http://www.hydraulicspneumatics.com/200/eBooks/Article/True/67859/
02/16/2010 6:17 AM
The pressure being added to the cylinder ports, and the formula for the area of a circle should be all you need. As stated by other posters, the function of a pneumatic cylinder is elementary.
Register to Reply 7 comments
Anonymous Poster (2); lyn (2); mohammad_irfan (1); pantaz (1); pipeit (1)
