Previous in Forum: Flat Spiral Spring energy   Next in Forum: pneumatic cylinder use
selection of flange material
02/13/2010 3:22 AM
why to go in for SA515plates to fabricate flanges insrtead of going for ASTMA 105 forged pieces.
Re: selection of flange material
02/13/2010 3:38 AM
Application? Temperature? Code requirement?
ASTM A105 is usually permitted upto 8000F
A515 (I presumed you have not mistyped and it is 515 and not 516) has upto 10000F as per section I (though as per section VIII it is same @850oF)
A515 is a coarse grained steel (and hence avoids graphitisation at higher temperatures)
look at application, be very sure before you try changing the specs.
02/13/2010 3:57 AM
application is cooling water and the temp. is max.200c.it is a low pressure fluid.
02/13/2010 4:56 AM
I really don't see any advantage of using SA515 instead of A105 for this type of service. May be cost ? (is 515 cheaper?)
02/13/2010 6:33 AM
Also you must note that 515 has a bit higher carbon (>0.30) , the PWHT may be mandatory (not sure, check up the relevant code) for this.
11/28/2023 3:23 AM
<...cooling water...max.200c...low pressure fluid...>
At that temperature, the saturation/boiling pressure is over 15barg. At lower pressures, it is steam, not <...cooling water...>.
Anonymous Poster (3); hemanjoshi (1); PWSlack (1)
