Previous in Forum: Thickness calculatiön for pipe   Next in Forum: FORMULA FOR SPRINGBACK
Design temperature
02/14/2010 4:57 AM
If the upset temp (ex: 120 Deg F) is more than the steam out temp (ex: 400 deg F), what is the design temperature?
Which code give solution for this situation?
Re: Design temperature
02/14/2010 6:58 PM
Please, reformulate your question. It is not possible to understand what is your problem the way you posted.
Humm... suspicious you are...
Good Answers: 61
02/14/2010 7:05 PM
Crajkumar,
It looks like you might have mixed up the basis for your question.
Should it have been:
"If the upset temp (ex: 120 Deg F) is less than the steam out temp (ex: 400 deg F), what is the design temperature?"
I recommend that you:
a) Determine the applicable design Code (i.e.: ASME B31.1, B31.3, etc.)
b) Apply the criteria from the Code
Do it once and do it right
Register to Reply 2 comments
