Previous in Forum: Rate of Helium Leak   Next in Forum: Elemental Mania: The Cost of Lithium
Composite plate to withstand 3500 Degree F
01/29/2007 1:10 PM
I'm looking for a composite plate that'll withstand 3500 Degree F for up to 5 minutes.
The plate will be used in the welding shop so it must take compression and shear loads from tools and raw materials.
Any ideas out there?
United States - Member - New Member Engineering Fields - Military Engineering - Member Engineering Fields - Mechanical Engineering - New Member
Re: Composite plate to withstand 3500 Degree F
01/30/2007 9:25 AM
what about carbon carbon,
or what type of materials do they use in blast/electric arc furnaces at steel foundries? I bet that would work.
01/30/2007 9:59 AM
Graphite will work.
01/30/2007 10:16 AM
01/31/2007 3:33 AM
Thanks for response.
Is graphite provided with glass fibers inserted as to prevent cracks?
The material I need must withstand pounding of metal tubes with-in a welding fixture.
I fear graphite alone would break down.
01/31/2007 11:05 AM
Glass will probably turn to liquid at the temperatures indicated.
02/01/2007 1:40 AM
you're right glass will liquid at the temps specified. I'll keep looking.
Register to Reply 6 comments
Anonymous Poster (1); cmnky26 (2); PWSlack (1); Zcarguy (2)
