Previous in Forum: Combining UV Wavelengths of 184.9nm and 253.7 nm   Next in Forum: Ventilation Ducts in Hospitals - HDPE or PP?
Eliminating Sulfuric Acid
02/16/2010 2:13 AM
hi everyone
i need help about 3m2 of old sulfuric acid we don't know to eliminate it plz help me
Pathfinder Tags: Old sulfuric acid waste
Re: problem with sufuric acid
02/16/2010 2:27 AM
Please check the unit. It is mentioned as Sq m. I presume it must be in Cu.M. What concentration it is?
02/16/2010 2:57 AM
yes its 3 m3 of an old sulfuric acid sorry my mistake but do you know how to make to eliminate it ? thanks
Good Answers: 101
02/16/2010 4:05 AM
Neutralize it with with lime. You can recover valuable gypsum for sale.
02/16/2010 3:03 AM
What part of the world? If you're in America, then you will likely have to contact a certified hazardous materials company to satisfy EPA regulations.
02/16/2010 1:34 PM
i m not in america i m in africa and our acid is an old concentrated sulfuric acid. so is it possible to add lime is it good for environement ?
02/18/2010 3:04 AM
The lime needs to be added slowly, as the reaction is exothermic. Continue until the pH reaches 7.
Calcium sulphate precipitates out of the solution, which has commercial uses and a value.
Re: Eliminating Sulfuric Acid
02/19/2010 1:20 AM
i have a concentrated acid and what if dilute the volume 1/10 and then i add solution of lime or simply lime directly?
Register to Reply 7 comments
DVader1000 (1); iserlohn99 (3); mrswamy (1); pantaz (1); PWSlack (1)
