I forgot my password.
Don't have an account?
hi..
right now we have job to design the steel tank that using anchor bolt type M24,M32 & M 42 but we doesnt have the specification about that ( the lenght detail dimension and the allowable tensile, please help us
best regard
Either you know not enough about the tank or you are not aware of the fact that for bolt design (anchor or others) much more data are required.
With what you give a correct answer cannot be available. You will get from other participants links but be careful since the risk is too high.
I only can recommend that if you will need a good preloading it would be better at this size to use tensioners instead of torque wrenches.
