Previous in Forum: Front Wheel Drive or All Wheel Drive?   Next in Forum: Electric Motor for Transpotation
12 comments
1999 Honda Accord - No Heat, No A/C
02/16/2010 3:14 PM
I have a problem with the air conditioning and heater not working at all.
I performed a basic check of the problem:
Check all the fuses under the hood, and inside the car, they were all OK, check to see that the compressor was turning, and that the belts were not broken, everything seemed OK, then I took the car to a Honda dealer for a diagnostic, the problem was diagnosed as a defective heater control panel. I went ahead and ordered the heater control panel from the Honda dealer, my question is, has anyone replaced a heater control panel recently? , if so, please describe the process for me, I sincerely appreciated it. I consider myself as a very handy person, but this will me help a greatly deal.
Thanks, Have a great day
Good Answers: 123
Re: 1999 Honda Accord - No Heat, No A/C
02/16/2010 6:56 PM
If you don't have a service manual for your car, it would be a good time to pick one up. The previous series Hondas were very simple to remove the heater control panel. Look at the bottom of the dash panel that the HVAC control mounts into. There will usually be two screws holding it in place. As you pull the bottom away GENTLY, look for areas that are resisting being pulled away. The places that resist, are either retained by more screws, or a snap in clip. Just continue to pull and look. When you find more screws, remove them, keeping the screws in groups, according to their placement.
Once you get to the HVAC control itself, look for anything that may have come loose that is causing your problem. If not, you will probably find a steel wire cable that changes the temperature of the air being sent into the cabin. Be careful with this. It can be difficult to remove. Here is where the book would help a lot. Once the cable is removed, the rest will only be wiring, and maybe vacuum lines. Just switch these over to the new control and try it out. Before you reinstall all of the parts, test the new part. If it does not solve your problem, at least you will have most of the hidden controls in your hands to do further testing. Good luck, and get the book.
Bob
02/16/2010 10:28 PM
Thanks for your valuable input. I will get the service manual, and I will give it a try.
Thanks
Jairo A
Good Answers: 123
02/16/2010 10:52 PM
Let me know if you need any help as you go through it.
Bob
02/17/2010 6:08 AM
http://www.ebay.com/ Search 1999 Honda factory service manual.
They had a few used manuals.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
02/16/2010 10:58 PM
Hi, when you say the heater and A/C are not working, can you clarify as to what's exactly going on? Is the blower not working, controls to shift the airflow not working, no cold air or hor air, etc?
As bob c said, get the service manual.
You'll find a lot of people who'll be willing to help. Complete information helps in the diagnosis.
Speak softly and carry a big stick.
Good Answers: 123
02/17/2010 9:12 AM
Good thought there. We were all assuming that the diagnosis that was made for the OP was correct. If indeed it is just the blower that has stopped, it may just need the blower motor, or related wiring for it. How about it there Mr(s) OP, what specifically is wrong with your HVAC system?
Bob
02/17/2010 9:25 AM
Sorry, I should have mentioned that earlier, the blower, and the fan speed do work, the air coming out of the blower is luke wrm, the rest of the controls are pretty much out.
Thanks
Jairo
Good Answers: 27
02/17/2010 9:40 AM
Another thing to check is the radiator thermostat. From your description it sounds like it is stuck open.
Good Answers: 123
02/17/2010 1:06 PM
Do you ever cross the border into Broward? I would'nt mind looking at it for you.
Bob
02/16/2010 11:15 PM
Just as a rule of thumb, if you have both AC and heat issues, it is more likely your control module or the electrical circuits associated with it, which is usually expensive and time consuming.
The common standard for control however, is vacuum. So if it is distribution that is the problem, not say, your blower motor or control for that, it may be the unit that switches via vacuum your vent system.
Every car is different, but replacing these units involve usually disassembling a faceplate or part of your dashboard, exposing the two basic connections, electrical and vacuum. The electrical and Vac terminals are "impossible" (ahem) to mix up, and replacement should be easy enough. Usually in my case I have had difficulty in disassembling the dash in the areas I need to access. Otherwise, if you have the part in your hand, the rest is fairly simple, and you should be on your way. (you may need torx screwdrivers)
In such a vast universe, I can only bask in my own insignificance....
02/19/2010 9:50 AM
Job completed.
Thank you all, for your valuable inputs, please see "Heater control panel" jpeg attached.
Regards
Jairo
Good Answers: 123
02/22/2010 12:32 AM
Congratulations. Thanks for posting back and letting us know. How bad was it to do?
Bob
Register to Reply 12 comments
Anonymous Poster (1); Bluestone (1); bob c (5); csoulpro (1); jama07 (3); standarded (1)
