Previous in Forum: Electrode 308 and 316 Material   Next in Forum: Perforated Pipe Question
Gas Infrared Ovens
02/16/2010 11:17 PM
Hi All
Does Anybody know about process cost saving when replacing conventional gas oven
by gas infrared oven in the process of drying ?
Ashraf
Pathfinder Tags: infrared oven
Re: Gas Infrared Ovens
02/17/2010 5:46 PM
A regular oven heats the air. So how much air is does it need to heat? Is the air that is heated being continuously exhausted? If so, whats the CFM and the temp of the oven? If direct fired, it should have almost as high of an efficiency as the infrared unit, but what is the efficiency? What is the exhaust associated with the burner? What is the Btu rating of the burner?
an infrared unit doesn't heat the air, and doesn't require burner exhaust. What is its efficiency and Btu/hr rating?
02/17/2010 11:00 PM
I want to explain my question .
Certainly if the hot air is directly fired then the conventional gas oven has greater efficiency than that of gas infrared oven .But overall efficiency may be less .
In conventional gas oven the carrier of heat is hot air .But we also know the hot air
has high capacity for water molecules (moisture / steam ) and these water molecules find less probability to escape from space inside the oven . So more heat
is required to give chance to escape resulting in the wastage of heat energy .
In gas infrared oven a high speed exhaust fan may be installed to evacuate the water
molecules inside the oven resulting in fast evaporation of water .Thus overall efficiency may be greater than that of conventional gas oven .
But the main problem is the uniform distribution of infrared radiations .
Ashraf
Register to Reply 2 comments
