Previous in Forum: LT3751 Charge Controller   Next in Forum: 200-kW Mill Motor on a 250-kVA Genset
10 comments
Cable Sizes
02/17/2010 7:26 AM
Load = 500Kw
length= 1 Kmeter
voltage= 400V
Barried by about 1meter
3phase
what is cable suitabe size can use
Good Answers: 29
Re: cable size
02/17/2010 11:11 AM
Try this. Keep in mind that these calcs are NEC. Don't know where you are.
http://www.electrician2.com/calculators/wireocpd_ver_1_parallel.htm
Re: cable size
02/17/2010 12:19 PM
Lets see a little effort from you.
Amp load = 500 kw/(0.400v x 1.73 x PF)
Check your code book for conductor that has this ampacity or greater.
Using the amps and conductor impedance calculate voltage drop
If VD is too high use a larger conductor.
Post your results so we can help.
Re: cable size
02/18/2010 9:56 AM
How to choose cable size? What is VD?
Life is fun.
Re: Cable Sizes
02/18/2010 7:50 AM
→ British Standard 7671.
Re: Cable Sizes
02/18/2010 11:51 AM
Dalai Quote "How to choose cable size? What is VD?"
This may be beyond you capability. You look in the applicable code book for you area for the conductor ampacity. Choose the conductor based on its ampacity or use the British Standard 7671. VD is voltage drop. It looks like you need some technical assistance beyond this forum
Re: Cable Sizes
02/19/2010 6:46 AM
Dear,
Your demand is unreallistic. Ur system current is 1137Amps. So there is no cable available according to ur requirements. Better way to change ur vtg level or use power distribution board and distribute ur load.
Re: Cable Sizes
02/20/2010 8:28 PM
abhishekkatkar Quote "Ur system current is 1137Amps. So there is no cable available according to ur requirements"
You need to check you calculations again. We don't know the PF but if it is unity the load is 723 amps. Ever heard of using parallel conductors? I am not used to using metric sized cable but 150 mm² = 380 amps x 2 = 760 amps. Is this not available?
Re: Cable Sizes
02/21/2010 3:28 AM
pf=90
and we need to use 4 core cupper armured cable
Re: Cable Sizes
02/21/2010 8:03 AM
thanks.i got it.
Re: Cable Sizes
02/21/2010 6:25 PM
1000 meters is too far. You will need to transform up to a higher voltage. If you use 4 KV, your load is about 100 amps and you can use a much smaller cable, something like 25 mm². Check you local code for the ampacity.
Register to Reply 10 comments
abhishekkatkar (2); Anonymous Poster (1); Dalai (1); PWSlack (1); RDGRNR (1); wareagle (4)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
