Previous in Forum: Design of Dummy Axle   Next in Forum: Hydraulics Hasten "Cat" Construction
g6
01/30/2007 6:48 AM
when specifying threads we specify it as e.g.,M85 X 2.5 6g.
what does it mean?
Re: g6
01/31/2007 8:24 AM
M85: means standard metric thread with nominal major dia. of 85 mm. Nominal dia does not mean that it will measure exactly 85mm... I've found a maximum reference in my local standard for M64, did you check the iso standard ? Maybe you can find more information there.
2.5: lenght of thread. Seems here to be informed in inches, or would not make sense.
6G: is the tolerance between the bolt and the hole where it will be bolted. It's the standard tolerance for diameters over M1,4
Humm... suspicious you are...
Re: g6
02/01/2007 10:48 PM
Thank you for the information.
United Kingdom - Member -
Re: g6
02/01/2007 5:03 AM
Hi,
As you have written it, this appears to be a metric thread as defined in BS3643 (probably an ISO standard by now):
M85 = the nominal O/D of the thread
2.5 = the pitch of the thread
6g = the normal tolerance class for an external thread
I don't know if this is an actual size that you're quoting, but 2.5 is a non-standard pitch for M85 thread.
Drew
Re: g6
02/01/2007 5:40 AM
Hi again,
I've just checked the BSI site and BS3643:1981 parts 1 & 2 is a current standard.
If you have a look in the standard it will tell you all you need to know about this type of thread.
Hope that this helps.
Drew
Re: g6
02/01/2007 11:24 PM
Re: g6
02/01/2007 10:57 PM
Register to Reply 6 comments
ad016 (2); bhrescobar (1); hemananda (3)
You might be interested in: Precision Locknuts, Thread Rolling Machines, Taps
