Previous in Forum: Does Anyone Build Models Like These?   Next in Forum: Specific Heat of Furnace Oil
13 comments
Steel Rod Challenge - Which One is the Magnet?
02/18/2010 1:47 PM
And here is another puzzle. On the table are two pieces of round steel rod, 10 mm diam, 90 mm long, polished, very smooth. Both are exactly alike, same color, same weight, they even smell the same. They are so alike that one cannot tell them apart. But one is a magnet and the other isn't. So with just the two pieces and your two hands, without any instruments or tools or any other assists, can you tell which is the magnet and which is not... and explain how you did it. This is not a trick question.
Re: Ghost
02/18/2010 1:56 PM
Except for "...they even smell the same.", this sound pretty familiar too:
http://cr4.globalspec.com/blogentry/10956/Magnetized-Rods-CR4-Challenge-12-15-09
Is that it?
Good Answers: 918
Re: Ghost
02/18/2010 4:17 PM
Good job.
Re: Ghost
02/18/2010 4:37 PM
Déjà vu, all over again.
Re: Steel Rod Challenge - Which One is the Magnet?
02/18/2010 9:14 PM
But there you had to be naked too . At least here you needn't.
Also the tables here are supposed to have some nails somewhere . These are ferromagnetic isn't it?
Good Answers: 94
02/19/2010 5:49 AM
Can I be naked if I want to?
Good Answers: 39
02/19/2010 1:13 AM
Touch ends to middle. The one with no attraction at the middle is the magnet.
Align culture with nature...
Engineering Fields - Optical Engineering - New Member
02/19/2010 1:23 AM
Try to balance each rod (axis), on finger tip. The magnetic one try to align itself to earth's magnetic field. We may able to sense slight movement or atleast some pressure (twisting movement) on our finger tip.With the non-magnetic one, no such force is observable.
02/19/2010 8:57 AM
Instead of using tip of finger to balance rods, pluck a hair from your head and use hair to suspend each rod from middle to determine which rod exhibits compass needle action. If your are bald, substitute a pubic hair. If you are pre-puberty, pluck out several nose hairs and braid them together to create a strand long enough to perform test.
02/19/2010 2:01 AM
There is no magnetic force in the center of the magnet. So moving one end of rod across the length of the other rod, You can know which is the magnet. If the stationary rod is magnet there will be no attraction at the center. If you are holding the magnet the attraction will be through out.
02/19/2010 4:51 AM
M.Premil Kumar
Vizag
19/2/2010
When I hold in the hand , the non-,agnetic roller will go towards the magnetic one. (i.e) Magnetic Rod will be static in its place and the other will run towrds it. Hope it is okay
02/19/2010 9:19 AM
No, it is not O.K. In fact it is a classic "schoolboy howler".
Reason: "Every action has an equal and opposite reaction" (Newton)
03/05/2010 12:03 PM
Sorry I am so late on this one. Just visited again and saw:
"Every action has an equal and opposite reaction" (Newton)"
Not exactly the quote... more like
"Actioni contrariam semper et æqualem esse reactionem: sive corporum duorum actiones in se mutuo semper esse æquales et in partes contrarias dirigi."
"To every action there is always opposed an equal reaction: or the mutual actions of two bodies upon each other are always equal, and directed to contrary parts"
While not a quote, an often used definition is 'If body A exerts a force on body B, then body B will exert an equal and opposite force back on A for the same period of time'.
02/19/2010 9:24 AM
If "not a magnet" means non-magnetic it can't be done, as the magnetized rod will not attract the non-magnetic one. If it means "not significantly magentized", see post #1.
Anonymous Hero (1); Anonymous Poster (4); canadianslidewinder (1); Doorman (2); g srikanth (1); narendra54 (1); Nigh (1); ormondotvos (1); redfred (1)
You might be interested in: Magnet Wire, Industrial Magnets, Stainless Steel Alloys
