Previous in Forum: Steel Rod Challenge - Which One is the Magnet?   Next in Forum: Gold Mold Casting
12 comments
Specific Heat of Furnace Oil
02/18/2010 11:41 PM
What is the specific heat of furnace oil, how much energy required to increase the temperature from 40 Deg C to 95 Deg C at a flowrate of 1200 LPH
Re: Specific heat of Furnace Oil
02/19/2010 1:27 AM
I tried looking this up and was surprised at the plethora of irrelevant info (such as combustion heat) that turned up, and the dearth of info on the specific heat of the fluid.
My wild guess: oil ≈ 0.8 (??). I'll keep trying.
Good Answers: 46
02/19/2010 7:17 AM
Engineer Tool Box liquids & fluids specific heat cap.
Yahoo Answers: What is the specific heat of heavy furnace oil.
hope this helps you.
Charles
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Re: Specific Heat of Furnace Oil
02/19/2010 9:37 AM
The flash temperature of #2 heating oil is min-max.. 52 - 87 dg C. Flash temperature means self-igniting. So it looks like heating it to 95 C is not a practical idea.
Reply Score 1 for Off Topic
02/19/2010 10:16 AM
Just a pont of order, if aI may. Flash point doesn´t equate to self-ignition. Strictly speaking FP is the temperature at which the liquid would ignite if and open flame were swept over the liquid surface on a open vessel.
Good Answers: 97
02/20/2010 12:07 AM
...er of course you meant auto-ignition
02/19/2010 11:41 PM
Heat transmission by McAdams reports a value 0.56 KCal/(Kg.DegC).
0.56 x 1200 x 0.87 x 55 KCal/Hr.
bioramani
Good Answers: 97
02/20/2010 12:10 AM
Specify grade of furnace oil #1, #2, #4, #6 etc..
02/21/2010 7:43 AM
From Tim Hawley Master Mech.
Hello Guest,
Your question is; How much energy is required to increase the temperature from
40 Deg. C or (104 Deg. F) TO 90 Deg. C or (194 Deg. F).
Energy is measured by (BTU) British Thermo Units. In order to measure BTU's you will have to provide the size of the heating area of the capsule you wish to increase the temperature by 90 Deg, F.
Please provide additional information , only then can an answer be provided.
NOTE: A race car high performance fuel pump output in Liters Per Hour is only 200 to 255 LPH. You must be powering a very large ship!
Best Regards,
Tim
Good Answers: 137
02/22/2010 10:25 AM
Can't agree with that. He asked for energy to heat the oil. As he gave a flow he should have said power, not energy, but that's a common mistake and it's fairly clear what he meant. Details of the equipment don't come into it.
And he referred to furnace oil, so it's likely to be a furnace or boiler he's feeding, not an engine. If it's a steam boiler I make it about 18 tonne/h steam output, which is biggish, but not huge.
Cheers........Codey
02/23/2010 7:53 AM
Hello Codemaster,
Fuel oil stoves have a carburator that regulates flow. The fuel oil flows in the a heat chamber. I want to know how large the heat chamber is. This is what I ment by "capsule".
Regards, Tim
02/23/2010 8:07 AM
Hello Guest & Codemaster,
Fuel oil stoves have a carburetor that regulates flow. The fuel oil flows in the a heat chamber. I want to know how large the heat chamber is. This is what I meant by "capsule".
1200 LPH is a lot of fuel. I measure 317 US gallons per hour, @ $2.80 USDollars per gallon equals 888.00 per hour to operate this beast.
My conclusion is this isn't a house hold heating stove. Give me the size of the heat chamber and I will calculate (energy required to increase 100 Deg. F).
Best Regards, Tim
09/10/2024 6:31 AM
How did the phone call to the supplier of the <...furnace oil...> go?
Where is the Materials Safety Data Sheet for the <...furnace oil...>?
Alexander M. Berlin (1); bioramani (1); bwire (2); Codemaster (1); coffeebean (1); metalSmiths (1); PWSlack (1); Tim Hawley Master Mech (3); Tornado (1)
