Previous in Forum: Chemical Mixtures   Next in Forum: Optical Coating
Welded Samples
02/18/2010 3:13 PM
We have been testing some alloys for service in 93 wt% acetic acid in water in the presence of 300 ppm chlorides. Two of the alloys 317 L and AL-6XN had corrosion rates of 150 mpy and 20 mpy respectively. We than tested the alloys when they had been welded together. One was 317L welded to AL-6XN and the other AL-6XN welded to AL-6XN. The weld material and techniques were identical. We found that the corrosion rate of the AL-6XN more than doubled but the 317 L fell dramatically. Does this make any sense ?
Re: Welded Samples
03/10/2010 9:14 PM
Hello "Guest". I have just noticed this plea for assistance and it's been sitting around for a few days.
Please understand that welding is NOT my field, nor is metalurgy so the following is only a guess, but might start some other discussion.
I suspect that what you are seeing is one of two effects.
My first guess is that the galvanic potential of the materials is causing the effect that you see where the AL-6XN is becoming like a sacrificial annode in the joined material.
The second guess is that the process of welding (heat induced) has caused local metalurgical changes in the materials that has made them susceptible to corrosion.
As I say, just a guess, but hope this helps.
Reply to Forum Thread
