Previous in Forum: Software for Industrial Plant Maintenance / Optimization   Next in Forum: An algorithm to find a pair of sums from a list of numbers?
24 comments
Lost Password - Can't Log On
02/19/2010 10:45 AM
Dell System DM051
While tinkering with my PC, I changed my password, and even thought I jotted it down, I still managed to misplaced and forget my new password.
Dell System DM051
Intel® Pentium 4 CPU 3.00GHZ
Ram= 1.5 G
I have 2 DVD devices, and 1 external HD
My operating system is Windows XP.
So far I try the following:
I type every combination of passwords that I am familiar with, no luck.
Down loaded a free password recovery tool into a CD, then I went into the Bios and reconfigure so it will boot from CD, no luck, and the system was looking for boot utility. This is an area where I am at a disadvantage; I don't this often enough to feel good about.
Note:
I don't want reformat my PC, unless I have to.
Thanks
I need a password reset tool, any suggestions will be welcome
Thanks
Have a great day
Pathfinder Tags: Lost password Unable to log on
Re: Lost password-unable to log on
02/19/2010 12:16 PM
Which password (BIOS or OS)?
02/19/2010 1:16 PM
Log in windows password, the Bios is fine, I am able to go into the BIOs and make changes
Thanks
Good Answers: 109
Re: Lost Password - Can't Log On
02/19/2010 10:51 PM
check this site out and then feel safe....not
www.wonderhowto.com/search/how-to-hack-a-password/
Hobbies - DIY Welding - New Member Hobbies - Car Customizing - New Member
02/19/2010 10:57 PM
I don't think anyone is gonna tell you how to do it.
Take it to the shop.
Don't forget your password next time.
02/20/2010 12:32 AM
Many times, I find that the "Administrator" user does not have a password. If that is so here, you can boot tapping the F8 key and select safe mode. The "Administrator" or "Owner" and all users with administration privileges will be offered for login.
Good luck!
avid0g
02/20/2010 12:55 AM
If you do a search on youtube for windows password reset you can find several walk-throughs. Take your pick of which one you want.
02/20/2010 1:51 AM
Try using the service from windowspasswordforgot.com I got several computers from a business and they were locked and the passwords were not available. downloaded the program and it resets all passwords to null. I think it costs about 30$ US.
I was impressed and still have the disk I made. So if I need it again I would imagine it would work on other machines. Was for windows XP.
Anything can be made, sometimes at great expense, resulting in greater satisfaction, :)
02/20/2010 12:21 PM
Hi,
You have several options, but the principal choice is do you want to know the password, or do you want to reset it. There are many internet sources which will wipe the password and ask you for a new one, but if you want to know the password, then go to:
www.loginrecovery.com
Their service is clever enough to take your uploaded LMHash and NTHash codes and reveal the passwords you put in.
You only pay a small fee if the system unlocks your passcodes successfully. Depending upon the complexity and number of passwords involved, the online process usually takes 5 to 30 minutes.
Hope this helps
Hugh Mattos Chartered Engineer...... :---------: Through helping others we give purpose to our time on this earth and take pleasure from it.
02/20/2010 3:44 PM
I recommend to contact Dell.
don't mind:
Normally lost /stolen systems need PW to boot & to help to find /Work around is not recommended.
02/20/2010 6:12 PM
Despite all the good hints, and good efforts from this forum, I couldn't come up with any combinations to unlock my system, so I purchased, and down loaded a Windows Password Recovery Tool 3.0 reset tool, user friendly, for the price of $19.00, this did the trick. If anyone is interested, or has the need, they are SWReg, Digital River, and here is the https://www.cardquery.com/
Thank you all for your expertise
Have a great day
03/19/2010 5:06 AM
You can use such windows password recovery tool to help bypass windows password http://www.anypasswordrecovery.com/ ,including your forgotten windows administrator password and user passwords.Try this.
03/19/2010 5:07 AM
05/04/2010 6:13 AM
HI!, I had met the headache things that I had forgotten Windows login password. The login screen rejected my passwords. I was frustrated because there was very important data on my disk and I couldn't reinstall the OS. ............. However, I fortunately got to know the Windows Password Recovery Tools below .
1. Windows Password Recovery Tool 3.0( http://www.windowspasswordsrecovery.com )
2. Windows Password Key 8.0( http://www.lostwindowspassword.com )
3. Windows Password Recovery 6.0( http://www.recoverlostpassword.com/products/windowspasswordrecoery.html )
4. Any Windows Password Reset 7 ( http://www.windowspasswordreset.net )
5. Windows 7 Password ( http://www.windows7password.net )
6. windows password cracker ( http://www.windowspasswordcracker.com )
I compare these tools and try the first one, it help me to recover my forgotten windows xp password in only five minutes.
if you want to know more detail of my process. you can email me by hecongyan@gmail.com , good luck.
Windows Security Expert
05/06/2010 9:33 PM
1.Using Computer Management from a remote Windows computer
Log on to another domain joined machine with an account, which is a member of the "Domain Admins" group. (assuming default policies)
Open Computer Management (compmgmt.msc)
Right-click Computer Management in the top left corner and select Connect to another computer from the context menu. Specify the hostname or IP address of your Server Core box.
Open the folder Local Users and Groups in the left side of the console
Open Users next
Right-click the Administrator account
Choose the Reset password task from the context menu and specify a new password.
2.Using the command line on the local Server Core box
Log on the Server Core box with an account, which is a member of the "Domain Admins" group. (assuming default policies)
Type the following command:
net user administrator NewPasswordHere
Log off by issuing the command logoff.
3. some useful articles:
1). How to solved the problem of "I Forgot My Windows XP Password?"
http://www.blog.lostwindowspassword.com/how-to-solved-the-problem-of-i-forgot-my-windows-xp-password/
2).Recover Windows Vista Forgotten Administrator Password
http://www.fixya.com/support/r4693954-rrcover_windows_vista_forgotten_administ
09/19/2010 3:44 AM
I have successful reset my lost administrator password with Windows Password Key
10/31/2013 3:01 AM
As a network administrator, I am always using PCUnlocker Live CD (http://www.top-password.com/reset-windows-password.html) for resetting lost Windows password. It should also work for your case!
05/25/2016 10:46 PM
what OS are you using... if XP, you can try a work around if the default administrator has no password on the user accounts screen, press CTRL+ALT+DEL twice type in administrator and press Enter. once you've successfully logged in, go to START->run then type 'control userpasswords2' then press Enter click on the account you want to reset the password then click the 'Reset Password' button. you will be prompted to type a new password. leave it blank if you don't want to have a password. log off and try your account again.
source: http://www.iseepassword.com/how-to-reset-windows-7-password.html
05/30/2016 2:35 AM
Does this above method works for domain password?
06/07/2016 10:29 PM
After two days researching, the password reset process can be done in minutes if you found the right program to do that. UUkeys has a nice windows password recovery tool and you can use it to burn a reset disk. Then reset the login password with the disk.
Tutorial:How to reset forgotten windows 7 password
11/23/2016 10:31 PM
I know how's the feeling of just can waiting and do nothing. But you can read this article. I think it may helps you, friend password manager for Windows
To be or not to be,this is a question
07/28/2017 9:59 PM
You can't logon your computer with password ? i also encountered this problem , a good Windows password recovery tool that I know about is recoverywindowspassword tool.
It can teach you how to reset Windows 7 password in safest way.
09/04/2019 4:48 AM
So far,i don't even know how to recover the lost password for Windows computer,i usually delete it to create a new login password.
09/04/2019 4:51 AM
So far,i don't even know how to recover the lost password back,as i usually delete it to create a new login password for my pc.
09/06/2019 5:59 AM
They will tell you exactly what to do(Remove/Reset password from Windows computer)
https://www.winpwd.com/
https://cain_abel.en.downloadastro.com/
Register to Reply 24 comments
Alicee (1); annyyu22 (1); Anonymous Poster (3); avid0g (1); Burnell77 (1); Haajee (1); hecongyan (1); HughMattos (1); jama07 (2); kevinm (1); killytu (2); Kmaslerazy (1); RicinCinci (1); romanjame (1); Sparksflew (3); sulewel (2); Swellmel (1)
You might be interested in: Switch Boots, Optical Storage Media, NVRAM
