Previous in Forum: enormous spending on wind mills & no encouragement for alternative cheap force.   Next in Forum: Battery Charging
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
function of vigi module
02/21/2010 5:01 AM
can a vigi module be used between 2 phases without connecting to earthing wire or a neutral wire?
shamith gambhir, electrical engineer
Pathfinder Tags: VIGI
Re: function of vigi module
02/23/2010 2:50 AM
i thought some of u might help me wit this......come on..i need some answers......its been 2 days
02/23/2010 3:01 AM
What is a vigi module?
02/23/2010 3:19 AM
its a protective device used to protect from earth faults, high short ckt currents etc....
Good Answers: 15
02/25/2010 1:13 PM
Hi SHAMITHGAMBHIR1:
As far as i am aware all Vigi units are differential units so you never need to connect an earth. You will need to pass a neutral wire though the CT if it is being used in the circuit.
regards
Chas
02/27/2010 1:58 AM
then how can it provide a earth fault protection without being connected to earth or a neutral wire?
Engineering Fields - Electrical Engineering - New Member India - Member - New Member
03/23/2010 2:52 AM
Dear Shamith,
I think this vigi module is a brand of Schneider electric. You can contact Schenider rep for more clarifications. they have a very detailed literature regarding RCCB and RCBO- right from fundamental explanation to application. for your information, for earth leakage protection, neutral connection is a must. whether 2 pole or 4 pole.
thanks
Register to Reply 6 comments
capblanc (1); PWSlack (1); SHAMITHGAMBHIR1 (3); shanbhag (1)
