Previous in Forum: Metal for HCL   Next in Forum: Pressure in Parallel Pipes
root clearance
02/21/2010 5:06 AM
hello
For measureing root clearance :
Is it correcr to measure the gap between top of the pinion tooth and bottom of the gear OR the gap between the top of the gear tooth and bottom of pinion?
thank you very much
Re: root clearance
02/21/2010 5:36 AM
Arn't they both supposed to be same?
Re: root clearance
02/21/2010 9:16 AM
Gear Teeth
ROOT CLEARANCE.—The designed root clearance with gear and pinion operating on their designed centers can be obtained from the manufacturer's drawing or blueprint. The actual clearance can be found by taking leads or by inserting a long feeler gage or a wedge gage. This clearance should check with the designed clearances. When the root clearance is con- siderably different at the two ends, the pinion and gear shaft are not parallel. Some tolerance is per- mitted, provided that there is still sufficient backlash and that the teeth are not meshed so closely that lubrication is adversely affected.
Re: root clearance
02/21/2010 8:55 PM
You were young seem to have grown younger (your avatar)
Re: root clearance
02/22/2010 7:44 AM
My first thought is that unless you are checking the gears on a checking stand you are going to be hard pressed to differentiate or even care. You are probably going to be cheek to metal with the gear in question while you try to manipulate a set of feeler gauges with one hand.
You are more than likely going to be concerned with the alignment end for end than you are which element you are dealing with. Unless of course this is an exercise.
If you fail to follow through, you will fail.
Register to Reply 4 comments
Anonymous Poster (2); lyn (1); otha (1)
You might be interested in: Rack and Pinion Drives, Rack and Pinion Gears, Gears
