Previous in Forum: Induction Oven for Melting Gold   Next in Forum: CO2 Molding
9 comments
Welded PTFE Tubes
02/22/2010 10:53 AM
Hello all, I have a project were I need PTFE tubes. The outer diameter is 42 mm, the inner diameter 40 mm (wall thickness = 1mm). I found several suppliers which are able to deliver the extruded one, but I'm looking for the (cheaper) lengthwise welded tubes. Does anybody know, where I can find such a supplier? Thanks and regards tischil
Pathfinder Tags: PTFE
Good Answers: 52
Re: Welded PTFE Tubes
02/22/2010 10:44 PM
Tischil,
Is your application mechanical, electrical, optical, thermal or chemical?
What pressure and pressure cycling is involved?
What temperature and temperature cycling is involved?
Are the PTFE tubes confined within a metal surround?
Is it possible to use other fluoropolymers than PTFE?
If you could be less mysterious and more descriptive, it may be possible to assist you.
Mark Bingham
Relativity PL
02/23/2010 9:13 AM
Thanks for fast answers!
I need this tubes to design a heat exchanger. The material must be resistant against aggressive chemicals (flue gas of waste incineration plant) and should be temperature resistant up to 250°C. No other material than PTFE can be applied. The thickness of 1 mm is very important because the heat transfer efficiency. In the past I used the extruded one, but know I'm looking for the mentioned welded tubes. I heard about it and I can't find it. Hope you can help me.
tischil
02/23/2010 11:12 AM
PTFE tubing is rated to 287 deg. C and PFA teflon tubing is rated to 260 deg. C.
I have always used the corrugated PFA tubing for my heat exchangers. As far as PTFE goes I have never heard of PTFE being welded only extruded, also PTFE will be less efficient then PFA for heat transfer.
02/23/2010 7:42 AM
Speaking of mystery, where did we loose 1mm of diameter or wall thickness?
02/23/2010 10:16 AM
42mm OD
-1mm wall
-1mm opposite wall
=40mm ID
Was that the question?
02/23/2010 6:39 PM
Fade to shot of ferrousfab slaping self on forehead.
08/13/2015 11:41 AM
Dear sir ,
Dongguan Suniu Electronics Co., Ltd profession produce ptfe tube 0.2mm-30mm . any inquiry pls let we know .
Best regards
coca
skype:liucoca
sales@ptfetube.co
www.ptfetube.co
02/23/2010 11:13 AM
Tischil there was a company called Process Supply in Charleston WV. They could weld/fab pure PTFE. This company was bought by Edlon, who in turn sold this company to Resistoflex Marion NC 828/724-4000. Maybe they can help you.
Good Answers: 97
02/23/2010 3:38 PM
Register to Reply 9 comments
Anonymous Poster (1); bwire (1); ferrousfab (1); GameJudge (1); lyn (1); ptfetube (1); Relativity PL (1); roadapple (1); tischil (1)
You might be interested in: Cores and Tubes, Microwave Tubes, Vacuum Tubes
