I finally finished the woodburner Iv had previously asked advice for, though its up and running it is by no means finished. The brief i set myself was to try to build a woodburner to heat the old pub i live in. I wanted it to be aesthetically pleasing, to have a big glass door to see the fire, for it to be top loading also as thats so much easyer. for it to have a double wall which i could route round bent steel pipes which would direct air into the fire, controlled by valves, and taking air around the combustion chamber to be pumped out into the room to act as a supper heater, either via a fan or passively via the pressure difference (these pipes could also be used to heat water) . I wanted to be able to re route the flue gasses into the burn chamber where they would be met with hot oxygen in order to secondary combustion to take place. And though i know little about this, i wanted it to have the potential to act as a gasifier.
here are some pics of what it looks like as well as a sketch of what is actually going on.
Sketch sorry this was done in about 1 minuet as thats all i had time for with the scanner hence very messy, will do another one soon with all the details, ect..
http://i810.photobucket.com/albums/zz28/theobrown/DSC03280.jpg
http://i810.photobucket.com/albums/zz28/theobrown/DSC03285.jpg
http://i810.photobucket.com/albums/zz28/theobrown/DSC03282.jpg
http://i810.photobucket.com/albums/zz28/theobrown/DSC03289.jpg
http://i810.photobucket.com/albums/zz28/theobrown/DSC03295.jpg
http://i810.photobucket.com/albums/zz28/theobrown/DSC03288.jpg
http://i810.photobucket.com/albums/zz28/theobrown/DSC03249.jpg
Now having fired it up, indeed it dose kick out a lot of heat, but not as well as i had hoped. Basically the problems seem to be
- The primary problem seems to be. The three air intake tubes do not seem to draw enough, as shown on the sketch they wrap around the inner burn chamber, which i though would give a good preheated air supply to, 1. straight under the grate, 2. above the glass acting as an 'air wash', 3. feeding into the top of the burn chamber to ideally to re ignite the flue gases. The only way to get round this is having the ash door ajar, making all this complex routing of steel pipe absolutely pointless.
In past experience only a little bit of preheated air going straight into a burn chamber is enough to make a fire roar, perhaps the 19 mill diameter pipe is just not big enough and the routing is to demanding.
I also think having the two pipes coming out of the back leading to the main flue should not have those 90 degree sharp elbows, would be better if they were curved elbows, my amateur understanding is that air speeds up when passing over a curved surface, though losses pressure. At the moment it must be quite jarring, restricting efficient draw.
I was very disappointed that the 'air wash' idea did not work, dose anybody have any suggestions on how a proper airwash system could be implemented. At the moment the glass is mostly completely sooted up but some areas are 'clean', they seem to occur where the heat is most intense.
I would very much appreciate some feed back
theo
