Previous in Forum: Too Big a Welder   Next in Forum: PM Format for HACCP Audit
15 comments
Automotive Locks - Best Material for Tumbler Disc and Key
02/24/2010 11:41 PM
We are in manufacturing of Automotives locks. Curently we are using brass material for both Tumbler Disc & Key. We want to replce this material from Brass to any other low cost material. Can any ony suggest me which material will be appropriate for this purpose.
Bijoy Santra
Also posted in: also posted in Transportation
Re: Material for Tumbler Disc & Key in Automotive Lock
02/25/2010 1:39 PM
Aluminum.
Most of the inexpensive keys and cylinders use aluminum components... easier to machine parts, the metal is less expensive... I know of no synthetic that should even be considered (there are some manufacturers making plugs and shells made of Delrin; these are available only on the cheapest of products. These still use alum pins and bronze springs)
Aluminum keys are more likely to twist off, usually inside the cylinder. Aluminum does not enjoy the lubricity of brass or bronze, so constant lubrication will be required. These issues will be a lot of fun for your customers. You can alloy the aluminum, but you will be right back at the price of brass.
It is certainly your product to design and market, but it seems there are fewer and fewer manufacturers using materials in their products that are known to last and provide acceptable service. Why not remain one of those few?
Re: Automotive Locks - Best Material for Tumbler Disc and Key
02/25/2010 11:47 PM
That's a good answer from Doorman. The reason for the use of brass is taht it's simply the best material for the job. The self lubrication factor is a real winner, as is the non-galling quality. The plastics also have some thermal stability problems, both in dimensional stability and in brittleness, particularly in low temp applications.
If all else fails, read the directions. That's if, and only if.
02/26/2010 12:53 AM
I appriciate your suggestion. But can we use stainless steel As per JIS 316. Bcz Cost of Stainless steel half of Brass and Stainless steel will serve our purpose also in term of mechanical strength as well corrosion resistance properties.
But I'm not sure whether manufacturing "key cutting" in stainless is possible not?
Please suggest.
I'm waiting for expert's view.
Bijoy Santra
02/26/2010 12:03 PM
Hello, Guest, ktel60, Randall, and Rhabe.
Dear Guest, will you be manufacturing the keys, as well as the cylinders? There are some facilities specializing in key blanks, as well as keys cut to specification.
"Stainless steel will serve our purpose also in term of mechanical strength as well corrosion resistance properties." Regarding strength, you are correct: SS keys will be unlikely to break EVER. However, consider the design failure sequence usually followed by designers: Cylinder will not turn easily (obstruction of unknown type), so inordinate amount of torque applied to key head. In failure sequence, it is more desirable that the key break off than an internal component deform or break. There is a tool, called a broken key extractor, that only is used for one thing.
"But I'm not sure whether manufacturing "key cutting" in stainless is possible not?" If you are asking about providing SS keys with your cylinders, yes you can. When using SS for blank material, most key manufacturers, because of the 'warding' of the plug, find that machining the intricate shapes along the longitudinal blade to be very time consuming, with an unacceptable number of out-of-limit key blanks. This together with the more expensive equipment required to cut the bit cuts (the edges of the key). This is part of the reason why keys made of Alum, Brass, or Nickel-Silver are more common. Easy to make blanks, easy to make duplicates.
Now, the preceding assumes you are using warded cylinders. If not, and these are disc locks (in lieu of pins or wafers), then a steel key (usually CR) is very commonly used. These have the distinct disadvantage of being very easy to manipulate (pick)
Randall, that sort of answers your question too... Conventional thinking is, the pins or discs inside the cylinder should be a little harder than the key itself; the key being easier to replace when worn down. Most manufacturers offering 'Commercial Grade' cylinders use bronze for the shell and plug, bronze impregnated with sulphur for pins (tumblers) and springs, and nickel-silver for the keys. This does make for an expensive combination of parts, but this type of cylinder will usually last for thirty years in the front door of an office building.
Hope this is useful... If not, I can post some illustrations or provide links for specific questions.
02/26/2010 2:43 AM
Doorman, ktel60
Could he change the locks to stainless steel but keep the keys brass?
Good Answers: 109
02/26/2010 8:55 AM
Hi,
usually: AlZn alloys for easy casting and limited self lubrication.
Or: AlCu (Al2024) or AlMgSi (Al6061) for high strength and medium to good anodising. Thick and hard anodised is equivalent to good sliding and low friction.
Any alloy shall be in STA status, may be over-aged is better than T6.
RHABE
02/26/2010 12:11 PM
I have another thought. I have re-read the original post: "We are in manufacturing of Automotives locks. Curently we are using brass material for both Tumbler Disc & Key. We want to replce this material from Brass to any other low cost material. Can any ony suggest me which material will be appropriate for this purpose."
There may be something I am missing in my previous comments. Bijoy, are you looking for help with the IGNITION keys?
If yes, please let us know. While my comments are correct in a general sense, most are not really applicable to the ignition keys of modern automobiles.
03/02/2010 5:57 AM
Hi Mr.Doorman,
Thank you very much for your quick & valuable response. Firstly, sorry to late response from my side. You are right that we are using the key in Ignition Switch Cum Steering Lock.
Secondly, we are using "Disc type tumbler" instead of "Pin type tumbler". Both Tumbler Disc & Key are made of Brass. My query was: are there any other suitable low cost material which can replace this brass, so that overall cost of the switch will be reduced without affecting its performance.
Bijoy Santra
03/03/2010 9:34 AM
Hello again, Bijoy Santra
I assume you are making an aftermarket (replacement) switch for older autos. That is to say, there are no transponder heads involved.
Locksmith Al said it completely and well: brass (or bronze) is used widely because it gives long service with satisfactory results. This has been so for many years.
You ask "are there any other suitable low cost material which can replace this brass, so that overall cost of the switch will be reduced without affecting its performance." The short answer, I believe, is no. I agree with Locksmith Al that SS parts (keys, in particular) will result in many problems. As my first comment, Aluminum (with some alloy) is used for parts in some cylinders with proven success. If you do this, the shell and plug can (possibly) go to ZAMAK 3 or ZAMAK 7 (http://en.wikipedia.org/wiki/Zamac#Uses), or some similar material. Are not these parts the larger consumer of metal for your cylinders? Zamak would probably not be suitable for keys and discs.
02/26/2010 2:44 PM
For the disc tumblers, brass is the ideal, with nickle silver running a close second.
STRATTEC here has aluminum wafers, they work, but they are subject to corrosion due to moisture, and in any kind of an alkaline environment will all but dissolve in short order.
HuF in Germany has used brass wafers in their locks, but steel keys, they work well, except for wafer wear over time.
Stainless keys are out of the question. The cutters used in locksmithing shops and the like are for the most part M2 carbon steel,and a stainless steel key is instant death on them.
Likewise with the equipment to cut a key using a punch and anvil to make the cuts. The tonnage needed to cut them in this manner is all but impossible for hand operated devices.
There's a reason brass and its alloys have been used for years in this application--it works!
Al
01/07/2012 4:52 PM
Auto Locks now use ALUMINUM wafers. This is an EDICT from government, not because it was found superior.
My preference on keys is STEEL. They are less prone to twist and breakage, and still can be cut on normal equipment.
MOST locksmiths in the US hate steel keys.
IMPROVING your designs to be better than the competition STRATTEC, ORTEC, HUF and others, should be top priority.
Moving factories to China and shaving cost will only be temporary, as car makers will go back to whomever can produce on-time delivery in the quantity required, and without the disasters that have occurred with poor designs/materials of the past.
In an auto lock, a little brass or aluminum goes a LONG way. Production savings through energy management and modern facilities that can change up processes faster should yield more savings.
If you develop a backward compatible cylinder, of sidebar design for GM that does NOT use a staked on spring-cap, you will have a winner. But it must be more durable than a Chrysler one, as those have a superior assembly, but high failure rate of jammed up wafers.
The world is also seeking a re-engineered replacement for ROVER ignition locks. A better cylinder design that does not fail out, and one that is modular for future serviceability.
You were vague as to your venture... OE CAR locks? SUV/Utility switches, or aftermarket auto?
Need a real-world, non laboratory peer-review on new designs? Happy to report on findings from prototypes.
Jeff
The Locksmith
I need all the equipment that "pays for itself" because I am tired of doing the paying !
01/10/2012 10:45 AM
The is NO EDICT from the government as to using aulminum instead of brass.
This is from a letter to all wholesalers from STRATTEC as to the productions changes and the reasons behind these changes.
I'll be more than happy to forward the letter and e-mail from STRATTEC as to their reasoning behind their decision, and it would be appreciated if individuals got their facts straight before posting conjecture on their part as fact or law.
February 2, 2005
STRATTEC is currently in the process of complying with a new requirement from General Motors, Ford, and Daimler Chrysler that requires us to remove hexavalent chromium from all our processes. For STRATTEC, the plating process is the area of change, and STRATTEC has chosen to move to a trivalent chromium process. This change will affect all cast and stamped components. We have also decided to replace most of our brass tumblers with aluminum tumblers, to maximize the performance related to the move to trivalent.
How does this affect you? In the coming year, you will see a change in color to your cast and/or stamped components contained in lock service packages as well as individual purchased components such as tumblers, cylinders and pinning kits.
Will there be a cost increase related to these changes? No. The cost incurred by these changes is not being passed on to you.
Is STRATTEC requesting a part number change? No. You can continue to order parts using the same part numbers. The changes will be handled as "running changes".
Is there a performance/capability issue between hexavalent, trivalent, brass and aluminum? All our testing shows that all four combinations of hex/brass (the current process), hex/aluminum, tri/brass, and tri/aluminum all pass the current OE automotive corrosion standards.
Will there be any issue with the mixing of brass and aluminum tumblers in the same lock while repairing? All testing indicates that the performance of the lock will not be affected when both brass and aluminum are used in the same lock.
If you should have any questions regarding these changes, please direct them to Fred Kosloske at 414-247-3331, Jeff Baker at 414-247-3421 or Vera Latus at 877-251-8798.
Thanks for your continued support of the STRATTEC product.
06/18/2012 12:21 AM
Al, consider the following:
__________________________________
Steps OSHA has taken to protectemployees from health hazards causedby hexavalent chromiumThe new OSHA workplace standard requiresemployers to:• limit eight-hour time-weighted average hexavalentchromium exposure in the workplace to5 micrograms or less per cubic meter of air.• perform periodic monitoring at least every 6months if initial monitoring shows employeeexposure at or above the action level (2.5micrograms per cubic meter of air calculatedas an 8-hour time-weighted average).• provide appropriate personal protective clothingand equipment when there is likely to be ahazard present from skin or eye contact.• implement good personal hygiene and housekeepingpractices to prevent hexavalentchromium exposure.• prohibit employee rotation as a method toachieve compliance with the exposure limit(PEL).• provide respiratory protection as specified inthe standard.• make available medical examinations toemployees within 30 days of initial assignment,annually, to those exposed in an emergencysituation, to those who experience signsor symptoms of adverse health effects associatedwith hexavalent chromium exposure, tothose who are or may be exposed at or abovethe action level for 30 or more days a year, and
at termination of employment.
This is an excerp from an OSHA publication.
Read the full publication at
http://www.osha.gov/OshDoc/data_General_Facts/hexavalent_chromium.pdf
I take that as a GOVERNMENT EDICT, if there ever was one !
06/18/2012 11:47 AM
And if you knew your metallurgy, you would know that there is NO chromium, hexavalent or otherwise, in brass.
Ergo, no Government edict, as I stated.
Locksmith Al
Reply Score 1 for Off Topic
07/14/2012 1:13 PM
Al,
"there you go again" lol
I am not saying there is a particular chemical in a particular finished product. But I can connect the dots.
Three major mfrs all come up with this requirement, if not for the fact the the manufacturing process of certain parts, requires presence of such chemicals, either as a lubricant or for other purpose; thus exposing employees to an unacceptable risk... this results in a GOVERNMENT edict, order, threat of suit or other pressure to change a practice to fulfill this "risk" abatement, be it real or imagined.
Subcontractors have to abide to the contractor, and meet all government requirements, so the easy change is to go to aluminum.... less hassle.
I see the argument is not over what is in Brass, but the process or facilities that produced the product.
Reply to Forum Thread 15 comments
Anonymous Poster (2); Doorman (4); Jeffrey Rosen (3); ktel60 (1); Locksmith Al (3); Randall (1); RHABE (1)
