Previous in Forum: Designing a Steel Tank (SA 36 Material) per UL 58   Next in Forum: Standard for Checking Isometric Trapezodial Threads
Axial, Radial and Transverse (or Transversal)
02/25/2010 9:39 PM
I have been doing technicial translation for over one year from English to CHinese and occasinally from CH to EN. Numerous times i have come across that three words in piping(tube), motor shaft related articles and I have been a little bit confused because different sources have different definition into these three words. Can anyone help to make a simple and clear explanation?
I am not a home work cheater. I am a translator seeking professional help
Location: West Point, Texas population around 200.Located between Austin and Houston
Re: "axial","radial" and "transverse"(or "transversal")
02/25/2010 10:18 PM
axial=axle in rick-oh-shay
radial=steel belted radial tires,look at your car
transversal=can I travel it?
transverse=He transversed the canyon with a wooden bridge.
We hold these truths to be self evident,one nation under God
Good Answers: 22
02/28/2010 4:42 PM
re: "transverse=He transversed the canyon with a wooden bridge."
I think you are confusing that with traverse.
ie He traversed the canyon with a wooden bridge.
Good Answers: 27
02/25/2010 10:45 PM
My understanding (open to correction) :
Axial - along the axis (for a motor, in the same axis as the shaft)
Radial - at right angles to the axial plain (in the direction of the "radius).
Transverse - Adjective - at right angles to an axis (crossways) - usually the long axis(Mathematics and astronomy use the term slightly differently)
Transverse - Noun - some thing that is at right angles.
Transversal - Noun - some thing that intersects more than one line or axis.
I have no special talent. I am only passionately curious. Albert E
02/26/2010 1:55 AM
This way for something having and axis transverse is radial?
02/28/2010 12:27 PM
Not necessarily. A radial line must pass through the axis (it is along a radius of the circle), a transverse line does not need to pass through the axis, but only be in a plane normal (perpendicular in 3D) to the axis.
A line between the tips of any two blades of a turbine rotor (or circular saw, etc.) is transverse, but it is only radial if the two blades are exactly 180° apart
Good Answers: 18
02/28/2010 1:20 PM
Kaizan's correct, but 'tranverse' needs more explanation.
Imagine a flat plane, say a piece of paper. Imagine that the length of the motor's circular shaft goes into and comes out the paper. The intersection of the shaft and the paper is circular ... it's the cross-section of the shaft.
The shaft's axis (assuming a circular shaft) is a line that 'goes into' and 'comes out of' the paper and that intersects the paper at the centre of the circular cross-section. The position of a point in relation to that line (the axis) is the point's axial coordinate, that is 'how far it is down the axis'. To determine the position, you draw a line from the point to the axis so as to form a right angle between the line and the axis.
Now, imagine that the piece of paper has the same axial position as your point. The line that you've just drawn to form a right angle (90 degrees) to the axis will appear as a line drawn from the point to the centre of the circular cross-section drawn on the paper. (Since the axis goes straight into the papet and out of it, perpendicularly to the paper, a line drawn to the centre of the circle on the paper will necessarily be perpendicular to the axis). The length of the line drawn from the point to the axis is the radius at which the point is located in relation to the axis. That length is the radial coordinate.
And now, the last coordinate. A point with known axial coordinate will be located on a plane perpendicular to the axis; we represent that plane by our piece of paper. If, in addition to that, we know the radial coordinate, then we know how far from the axis the point is. That being said, the point's location can be anywhere of a circle whose radius from the axis is equal to the radial coordinate. Now, we have to say where on the circle of known radius the point is located.
We do that by measuring the angle between the line drawn from the point to the centre of the circle (i.e., to the axis) and a line drawn from the centre in any direction on the piece of paper. That line we define as being the reference line for measuring angles ... by definition, its direction is zero degrees.
So, the angle formed between the radial line drawn from the point to the circle's centre (the axis) and the reference line (zero degrees) is the 'tranverse' or 'angular' coordinate that locates the point precisely in space.
Summarily:
- the axial coordinate defines where our piece of paper intersects the motor shaft, perpendicularly; our point is located somewhere on that piece of paper;
- the radial coordinate tells us how far the point is from the centre (the axis) of the shaft whose cross-section is circular; with the axial and radial coordinates, together, tell us that the point is on our piece of paper (axial coordinate) and that it's on a circle of a given radius (the radial coordinate) and whose centre is the shaft's axis;
- the tranverse (i.e., perpendicular to the radius) or 'angular' coordinate tells us where the point is one the circle defined by the axial and radial coordinates.
And of course, now is when I realize that I could have just pointed you to Wikipedia. The coordinate system that I've described is the polar coordinate system. Here it is on Wikipedia: http://en.wikipedia.org/wiki/Polar_coordinates
DZ :-S
Do unto others. Then run.
Good Answers: 18
Re: Axial, Radial and Transverse (or Transversal)
02/27/2010 12:15 AM
In three-dimensional space, you have to provide three coordinates to give the location of a point. We're used to working in x-y-z coordinates, but position can also be given using other coordinates.
To give the location of a point in a cylinder, you do it using:
- position along the length of the cylinder (more precisely, of its central axis); this is the axial coordinate; this coordinate is a length, so measured in metres, inches, or similar;
- the distance away from the cylinder's central axis, in other words how far the point is along a radius starting at the central axis; this is the radial coordinate; this coordinate is also a length;
- the angular position of the point in relation to an angle considered to be zero; for example, when looking alont the length of the cylinder (i.e., its axis), if the direction straight to the right of the axis is defined as zero degrees, the position straigh up is 90 degrees, etc; this coordinate is an angle, most often given in degrees.
So, for example, for a point located five inches along the length of a cylinder, one inch to the right of the cylinder's axis, and one inch upwards, the coordinates would be: (5 inches (axial), root-two inches (radial), 45 degrees (transversal)).
The radial distance of a point one inch to the right and one inch up equals (root(one-squared + one-squared)) = root-two.
The angle for one inch right and one inch up is 45 degrees.
Hard to describe in words, much easier to visualize as a diagram, but hope this helps.
Cheers! DZ
Register to Reply 7 comments
Anonymous Poster (1); dkwarner (1); DreadZontar (2); Judge (1); Kaisan (1); OldTechNewToys (1)
