Previous in Forum: Fitness for Service - Brittle Fracture (API 579, Part 3)   Next in Forum: Bearing Spacer Tolerance
What's a Crankcase?
02/26/2010 10:51 AM
hi all..........i want to know about what is meant by a crankcase and where it is used. i've searched google, but i didn't understand the information given in the internet.
teja
Re: crankcase
02/26/2010 11:10 AM
How did you google?
Results 1 - 10 of about 397,000 for what is crankcase. (0.08 seconds)
and quite a few detail about it. (in fact about the crank case oil too)
Re: What's a Crankcase?
02/27/2010 6:12 AM
It is the case in which a crankshaft is mounted.
So in a car engine it is the lower half of main engine block usually cast iron or aluminium alloy which houses the main bearings on which the crankshaft rotates.
Register to Reply 2 comments
