Dear Friends ,
I have a cascade loop in which the outer loop is air flow ( 350 mm line , butterfly valve ,orifice and Dp transmitter ) and the inner loop is oil flow control ( line size is 1", with mass flow meter as the measuring device and globe valve for control ) .The Control system is Yokogawa CS1000 DCS . Now my problem is when the loop is put in cascade mode the flow varies in the range of 90 to 120 Kg/Hr ( total oil flow range is 3000 Kg/Hr ) , where as when we put the flow loop in auto mode the fluctuation is only 10 Kg/Hr . So we assume that the fluctuation is introduced by the air flow loop, but since it is a butter fly valve with pneumatic actuator can we get better control over there?. is there any other alternative ?.
Regards ,
Ajith
