Hi! My design of Flue gas heat recovery system is complete. I am utilizing heat pipe stack to pre-heat the feed water using the heat from the exhaust flue gases of a boiler. The temp of flue gas at the entry of the system is at 230DegC. I am stuck with the selection of the material for the casing. Can somebody please offer some suggestion on this. I am deliberating between Stainless Steel, Galvanized iron and High temp paint on MS. My confusion is that Stainless steel increases the cost of the system and other two may not be durable long enough.
Thanks folks!
