Previous in Forum: Circuit for Hydrogen Sensor   Next in Forum: Run Back Scheme
Calculating Power Output and Full Load Line Current
02/28/2010 7:27 PM
Hi
I am presently studying Electrical Engineering Cert III and as much as I ask the lecturer for help, he is very scientific and I find it hard to understand him.. so I'm hoping someone can give me very basic maths answer that is easy to understand..
Calculate the power output and full load line current of a three-phased induction motor, given the following specifications..
Efficiency: 85%, Power Factor 0.85lag, Supply voltage 415v, Torgue 65Nm, Speed 1440rpm, 50 hertz.
I did the power output as follows, plz correct me if I am wrong
P/out = 2 x Pi x 1440rpm x 65Nm / 60 = 7759watts
Is this correct and how do I calculate the load line current?
Many Thanks
Re: calculate power output & full load line current
02/28/2010 9:09 PM
Motor input = electrical power
Output = mechanical power
Output = input x efficiency
Electrical power = VICosΦ Single phase = √3 VICosΦ (3 phase)
Mech power = Tω
Take care of units (rad/sec, N-m, ...)
03/01/2010 11:14 AM
P input (3P)=1.732* VL *IL* COS(ANGLE)
Pin/ (1.732 *415* 0.85) = IL;
Pout/Pin = EFFICIENCY
Pout = [(torque * rpm)/5252 ]*746 =13295
pin= 13295/0.85= 15641
IL= 25.6A
Recheck this with calculator.
Please dont give home work again :)) dont mind
Belgium - Member - New Member
Good Answers: 21
Re: Calculating Power Output and Full Load Line Current
03/02/2010 7:17 AM
mechanical power = torque x angular velocity
  • P mech = T x ω
  • = T x Nx2xpi/60
  • = 65 x 1440 x 2 x 3.1415 /60
  • = 9801 Watt
  • this is the mechanical power at the output shaft of the motor
electrical active power x efficiency = mechanical power
  • P elec activ x η = P mech
  • P elec activ = P mech / η
  • = 9801 / 0.85
  • = 11531 Watt
  • this is the electrical power we have to pay to the energy compagny
electrical active power = current x voltage x sqrt(3) x power factor
  • P elec act = I x U x 1.73 x PF
  • I = P elec act / (U x 1.73 x PF)
  • = 11531 / (415 x 1.73 x 0.85)
  • = 18.9 A
  • this is the current which runs through the supply cable from the energy compagny to the motor
electrical total power x power factor = electrical active power
  • P elec total x PF = P elec act
  • P elec total = P elec act / PF
  • = 11531 / 0.85
  • = 13566 VA
  • this is the size of the transformer the energy compagy has to have to feed the motor
electrical total power2 = electrical active power2 + electrical reactive power2
  • P elec total2 = P elec act2 + P elec react2
  • P elec react = sqrt (P elec total2 - P elec act2 )
  • = sqrt (13566 2 - 11531 2)
  • = 7146 VAR
  • this is the amount of power we could get out of a power factor correction capacitor installed near the motor. So this power will not flow through the supply cable from the energy compagny. The Power factor will be "one". In this case the energy compagny only has to deliver the activ part of the total power
current in supply cable when the energy compagny only delivers the activ part of the total power
  • = 11531 / (415 x 1.73 x 1)
  • = 16.06 A
  • this means the surface of the supply cable can be smaller or a cheaper cable
03/02/2010 9:44 AM
pout(hp)=2piNT/33000, pin(watts)=pout(746)/efficiency, if your looking for the full load current, I=pin(watts)/1.737xVxpf
03/02/2010 4:14 PM
Thank you to everyone who has replied...
allyrat
03/03/2010 4:50 AM
Steps:
This I have already explained in #1 but again
You have an electro-mechanical system
Motor- Input power is electrical, output is mechanical (remember for generator it will be exactly opposite - for your next question )
The input power in electrical we express as
P = V.I - Note this is a phasor dot product (almost like vector)
= VI CosΦ ,
where Φ is the angle difference between the two phasors, but this angle is not in physical space but in time phase. So if you assume for simplicity the frequency is say 50 Hz
That means the voltage (and current) is oscillating 50 times every second. (Every single oscillation takes 1/50 = 0.02 seconds)
This 0.02 seconds in this phasor equals 360 degrees
If say the current zero is 0.001 seconds after the voltage zero, then we say
Current is lagging the voltage by 0.001/0.02 x 360 = 18 degrees.
As you see above, the ideal power is when both current and voltage are in phase (ie F = 0)
P = VI Cos 0 = VI
This factor (of power) , CosF is introduced due to the phase difference and is called the power factor.
In other words, the power factor is the factor by which the actual power is less than the apparent power. The actual power is the only part that can be converted to other form of power (eg mechanical, heat, light etc) and taken out of the system.
As said above ,
P = VICosF , is actually for single phase, ie when you have the line and the neutral connected to a load.
But if you are working with 3 phases (with or without neutral) , the power equation becomes
P = V1I1CosF1 + = V2I2CosF2 + = V3I3CosF3
(1,2 3 are individual phase values of voltage, current and phase shifts)
If you have a balanced 3 phase, it simplifies to
Pelect = Ö3 VICosF (1)
(It is not 3 but Ö3 since in case of 3 phase supply, the line voltage itself may be Ö3 times the line to neutral voltage in case of star connection, and it is the current in case of delta connections)
Mechanical power, is simply calculated, as you have done,
Pmech = Torque x Angular speed. (2)
Then the third part
Output = efficiency x Input power (3)
Out of all these (1), (2) and (3)
You have all the required inputs (except single unknown- current) to calculate Pelectr, Pmech and you know the efficiency.
Hope now you can solve it.
Note:
In case of motor, as is this one, Output is the mechanical, input is the electrical, so
Pmech = Efficiency x Pelect
In case of generator it will be reverse ie
Pelect = Efficiency x Pmech
Note-2
Remember also the caution of #1
The units, In SI,
Torque should be in N-m, Speed in radians per second (son you must convert RPM into radian per second)
Voltage in Volts (you may get questions with KV or MVs also) the current in amperes.
The power should be in watts, in case anything else (HP etc) convert into watts. Take care of any other such aspects.
Register to Reply 6 comments
allyrat (1); Anonymous Poster (3); jhonson (1); rudy.leurs (1)
