Previous in Forum: CT Metering Core Resistance   Next in Forum: Calculating Power Output and Full Load Line Current
Circuit for Hydrogen Sensor
02/28/2010 11:36 AM
Hi all,
I need some help about hydrogen sensor circuit.A hydrogen sensor is available with specs as:
input voltage:5 v
Range:0-14000 ppm of H2
I need to make a circuit for detection level of 25% LEL ie. 1% of H2 in air or u can say for 10000 ppm of H2.At this ppm of H2 i will get 3.5 volt of Vout.I am going to make an emergency shutdown circuit using hydrogen sensor.Advise me to do that in a simple way.
Regards
Hashim
Hashim Khan,Automotive engineering Student
This discussion was "closed" on 03/01/2010 8:50 AM. No new comments are allowed.
Re: Circuit for Hydrogen Sensor
02/28/2010 7:01 PM
I maybe overly paranoid, but this is a simple comparator circuit. But you're measuring the concentration of a flammable gas and asking for a trip condition at twice the minimum explosive threshold. Lastly, you post that you are from a volatile region of this world right now.
You might have an honest reason for this question but I don't feel right answering this.
03/01/2010 8:12 AM
Hydrogen, in air, has roughly the following limits, by volume:
4% = Lower Flammability Limit (LFL)
15% = Lower Explosive Limit (LEL)
58% = Upper Explosive Limit (UEL)
72% = Upper Flammability Limit (UFL)
Sometimes the LFL and LEL are assumed to be 4% and the UEL and UFL are assumed to be 72%, to be safe in avoiding both deflagration and detonation.
The 1% setpoint is reasonably protective. I've seen 2% used as well.
I'm not I&C so I can't answer the instrumentation circuit design question.
"For a successful technology, reality must take precedence over public relations, for nature cannot be fooled." -Richard Feynman
03/01/2010 2:59 AM
Other options are:
  • concentrate on why the process hydrogen is so poorly contained and improve it
  • concentrate on improving the ventilation in the area
03/01/2010 4:13 AM
Register to Reply 4 comments
Anonymous Poster (1); N&P (1); PWSlack (1); redfred (1)
