Previous in Forum: Solution Concentration   Next in Forum: PLC Training
Pressure-Activated Buttons
03/01/2010 11:21 AM
Hi everyone,
I'm a product design student and I'm currently working on a project designing a new personal alarm worn on the wrist. I want the alarm to be activated by applying a pressure on two 'buttons' so the buttons can only react if the specified force on the buttons have been reached. Does anyone have any idea where or who I can contact to find such buttons? It's basicly buttons to turn a circuit on and off by applying a force.
Thanks,
Weewoo
Also posted in: also posted in Engineering Projects
Re: Pressure-Activated Buttons
03/01/2010 2:23 PM
For a slim-line package as the one you are working on the best idea I can suggest would be to use standard low profile tactile switches (for example the one below or similar) which are available from your local component distributor,
http://www.newark.com/omron-electronic-components/b3f-1025/tactile-switch/dp/89C4134
http://www.newark.com/switches
and recess and cover them with a flexible plastic sheet (adhesive plastic film or similar works really well and is quite inexpensive and easy to work with) which forms a cover (and also forms the front of the personal alarm). The force necessary to activate the switches can be controlled by the use of different cover materials and thicknesses as well as the depth of the depression through the cover necessary to activate the tactile switches.
This is a common method of switch control in the industry and I have used exactly the same thing for wall-mounted equipment in harsh rural farm environments (example custom label supplier shown below, although you can order sheets from suppliers or possibly even large office stationary suppliers).
http://www.permark.co.nz/Services/Graphic+Overlay.html
As an added advantage this also adds to the alarms weather resistance by sealing the switches (important for an electronic device worn on the wrist). Two button activation is just as simple with this method by having a plastic or similar partition separating the switches to prevent accidental activation by a single finger or object, but still allowing easy activation of both switches using two fingers on one hand.
Another possible option is the common membrane switch which has the switch element built into the plastic film. This is a bit more difficult to work with and design for a low quantity product run, and so may not be viable for your particular needs (but is worth a look).
http://www.permark.co.nz/Services/Membrane+Keypad.html
http://en.wikipedia.org/wiki/Membrane_switch
03/02/2010 11:37 AM
Hi thanks for your help. You're so full of knowledge!
I'll look into both options but so far other people I have spoken to also suggest looking at membrane switches!
Weewoo
03/02/2010 2:49 PM
Your welcome.
Good Answers: 60
03/05/2010 5:56 PM
Register to Reply 4 comments
jack of all trades (2); peterg7lyq (1); weewoo (1)
