Previous in Forum: ATV61 Problem   Next in Forum: Machine Hearing Plays Catch-Up
12 comments
Generator Capability Curve
02/01/2007 7:20 AM
Respected members,
I want to know how to develop soft copy of 60mw, 11.5kv ; 50hz; 0.9pf generator capability curve for incorporating in plant D.C.S. Can anybody help me?
Electrical Rao
Good Answers: 247
Re: Generator Capability Curve
02/02/2007 1:55 PM
You may need to supply more information: the obvious answer to developing a soft copy of a graph is to select "print". By DCS do you mean Detector Control System or distributed control system? Interesting assortment of electrical values.
02/06/2007 6:56 PM
Dear mr. Blink,
thank you for your reply.
using generator parameters like MW, MVAR, POWER FACTOR, TURBINE CAPACITY, STATOR CURRENT , IMPEDANCE VALUES, THE CURVE TO BE DEVLOPED IN WHICH THE GENERATOR CAN OPERATED WITHIN TURBINE CAPACITY, STATOR CURRENT RATING, LEADING MVAR AND LAGGING MVAR CAPABILITY LIMITS.
USING SUITABLE TRANSDUCERS in C.Ts and P.Ts circuit, out put of transducers will be fed to the indicating system. depending on loading of generator, operating point will appear on the screen over which this capability curve will be insctribed. then operator will know whether the generator is operating within its' capability or not.
WHAT I MEAN FROM D.C.S IS DISTRIBUTED CONTROL SYSTEM
BEST REGARDS,
ELECTRICAL RAO
Good Answers: 247
02/06/2007 9:21 PM
Thanks Electrical Rao:
That makes it more clear. I think of mw as milliwatt, and MW as megawatt. I also think of pf as picofarad. So the combination of high voltage, but tiny wattage, and low frequency but tiny capacitance had me puzzled. But with megawatts and power factor, (instead of milliwatts and picofarads) it makes sense.
Are you looking for someone to develop the entire system, transducers, software and all, or help with a particular part of the system? There are several power generation people who frequent CR4 and could help, I think. You may want to post again, with additional details on exactly what help you are seeking.
Best wishes,
ken
02/02/2007 9:30 PM
You would get it from the Engine/DG Pakager when they do engine/DG load test in fact they would have generated documents much more then what you are looking at.its not so easy to develop the curve you are looking at in field.It would cost you Heven.&earth
crm
09/05/2008 4:33 AM
i am P-Q capability software developed in Industrial ethernet protocol if you want cantact me
prabhu.shanker@gmail.com
03/17/2010 1:01 AM
Hi Mr Rao
The Generator Capability curve is made by Generator Manufacturer depending on
Stator Winding Temp Limitation
Mechanical Power capability of Turbine
Stability of Excitation system --Under exitation etc
Please Try to look at it first
Then it is a simple XY plot using a Function Block
First a Graph is made with the curve
Then XY co ordinatos are assigned to MW & MVAR
Let me which DCS you are using i.e SIEMENS / ABB etc
regards
Vijayakumar
03/17/2010 2:26 AM
THANK YOU Mr. VIJAY KUMAR,
I STARTED DEVELOPING THE CURVE USING THE DATA AVAILABLE. I AM SUCCESSFUL TO SOME EXTENT. OF COURSE MY WORK IS FOR CYL. ROTOR UNITS(TURBO GENERATORS).
EVEN LEADING MVAR LIMITATION ALSO TAKEN INTO CONSIDERATION. P.F LINES ALSO DISPLAYED. WHEN IT IS CHECKED FOR ITS' CORRECTNESS WITH THE MANUFACTURER CURVE I WILL COME BACK.
Mr. VIJAYKUMAR, CAN YOU PLEASE INFORM, WHERE FROM YOU ARE. I AM IN HYDERABAD AND Ex. EMPLOYEE OF A.P.S.E.B
THANK YOU
ELECTRICAL RAO
03/17/2010 11:14 PM
Hi Mr Rao
If you are ex APSEB , i am also ex APSEB Kothagudem , Vijayawada
regards
vijayakumar
03/18/2010 3:47 AM
RESPECTED VIJAY KUMAR SAAB,
NAMSTE,
ARE YOU EX-TECH DIRECTOR GENCO. Sri. G. VIJAYA KUMAR.
I AM C.SIVA SANKARA RAO EX-A.D.E M.R.T/KTPS - A
CAN YOU PLEASE REPLY.
ELECTRICAL RAO
03/18/2010 4:46 AM
Rao Garu
I am the Other
I expected that you are Sivasanker Rao
Any way it is my pleasure to come in contact with you once again .
I am also happy to note that you are active
Thanks for you visit to my Home
My wife is now with me and she brought the Vedio and i Have seen you in that
anyway my present job is in Electrical & Instrumentation departments .
Most of my time is spent on Projects . I am fortunate enough to be a member of Rehab team for Riffa Power Station .
I did on own the following Projects
220 KV sub station control desk replacement through ABB DCS
66 KV Sub Station control desk replacement through SIEMENS DCS
5 MVA & 2 MVA Electrical & control system Replacement using
Siemens PLC and DCS
Gas Station Electrical & control system Replacement using
Siemens PLC and DCS
Complete Electrical & Instrumentation system for Gas Turbines of 75 MW
I am involved with the specifications and purchasing of 100 MVA Generator Transformers .
Convey my regards to Kamala Garu
My contact no is 00973 36052535
I am fully fimiliar with DCS
Let us exchange information
Regards
vijayakumar
03/18/2010 9:31 PM
RESPECTED VIJAY KUMAR GARU,
NAMASTE,
I AM HAPPY TO NOTE THAT YOU ARE ACTIVE IN REPLYING TO THE THREADS.
CONVEY OUR REGARDS TO YOUR FAMILY.
SINCE LONG TIME I AM WORKING TO DEVELOP GENERATOR CAPABILITY CURVE. NOW ON MY OWN I DEVELOPED THE CURE FOR CYL. ROTOR GENERATOR. IT HAS TO BE GIVEN FINISHING TOUCHES BY ADDING MORE POWER FACTOR LINES. IN THIS CURVE EVEN LEADING MVAR LIMITATIONS ALSO TAKEN INTO CONSIDERATION.
BEST REGARDS
03/18/2010 3:53 AM
RESPECTED VIJAYKUMAR SAAB,
NAMASTE,
ARE YOU Sri. G. VIJAY KUMAR, EX- TECHNICAL DIRECTOR, GENCO.
I AM C.SIVA SANKARA RAO, EX-A.D.E/M.R.T - A STATION, K.T.P.S
PLEASE REPLY.
ELECTRICAL RAO
Register to Reply 12 comments
Anonymous Poster (6); Blink (2); electrical rao (1); vrks1946 (3)
