Previous in Forum: Looking for Optical Simulation Software   Next in Forum: MSMoney File Issue
Freeware for Removing All Data and Partitions
03/02/2010 3:59 PM
HI ALL
Just installed a new 160 GB hard drive into my ACER Aspire 3000.
Using the Partitioning utility of an original XP-Pro Installation disk, I partitioned the Drive into 4 Part(ition)s, in order to be able to run XP and SUSE Linux as a dual Boot on the Laptop.
However, Installation of XP-PRO on a 40GB Partition failed twice (no linux installed yet), ending up in confusing blue screens and typical MS "there is a problem" Messages which only a Computer doctor can comprehend. 19 GB of the 40GB Partition are now full of unusable Windows XP .
Now I want to completely remove all Data and partitions from the drive, ending up with an "as new" drive to be able to start from scratch, with no residual Microsoft data on it.
Is there a free tool, bootable cd, to perform such an operation. There is no working OS on the drive now, so it would have to run off a cd.
Thankful for any simple suggestions,
Hangwaiter
Re: Freeware for Removing All Data and Partitions
03/02/2010 4:25 PM
Fortunately I have never needed to do this.
I cannot remember if there is a format function available thru the motherboards BIOS, but I would not have thought that the CD drive (or USB ports) would work if the OS failed as the CD drivers are part of the OS.
If you have a working computer available I would suggest connecting the ACER's hard drive to it, booting up the working computer and then performing a simple 'format hard drive' using the utilities built into windows (or what ever OS the computer has). Just make sure you format the right drive!
Good Answers: 97
03/03/2010 12:14 AM
Uh-uh, the CD drivers are loaded to the motherboard...
Good Answers: 213
03/02/2010 10:43 PM
You might try the Suse LiveCD- reformat the disc into a single FAT32 partition, using the Suse install partitioner, then abort the installation (Windows has to be installed first). Then try installing the Windows XP fresh on the hard drive. AFTER installing Windows, return to the Suse LiveCD to install Suse. I¡m not absolutely certain about this procedure with Suse, but it works with Ubuntu (a scheme I use for cleaning up virus infections and such).
Good Answers: 119
03/02/2010 11:24 PM
I run Ubuntu Linux now on all newer hardware. You can create a "live" bootable CD from an iso image downloaded from their website. The partition editor or "gparted" will be available from a CD boot and can nuke all the old partitions. I also use the tiny "Puppy" Linux for older (slower) hardware. You can create a bootable CD from their site as well and then run their version of "gparted" to clear the old partitions.
You should be able to do the same thing with SUSE Linux, but I'm not familiar with that distribution.
There is also a free version of killdisk available which can clear a drive. The free version won't get you DOD level data erasure, but it should do what you want.
XP is usually pretty easy to install (IMHO Linux is easier!). Your troubles may be due to some abnormal bios setting or a hardware conflict. Either way, best wishes.
Edit: Let XP create the windows partitions (NTFS) only. Leave the Linux drive space blank. After XP is installed, THEN use the Linux CD to create and format the Linux partitions and the install the grub (or equivalent) dual boot loader. Installing Linux onto the new partitions this way usually gives the best results. Good Luck!
Location: West Point, Texas population around 200.Located between Austin and Houston
03/03/2010 12:06 AM
format/s
Format with system gives you the fat of the system used to format it.
Joe in Texas
We hold these truths to be self evident,one nation under God
Good Answers: 97
03/03/2010 12:19 AM
Kill Disk is disk eraser software for secure formatting of hard drives without any possibility of following data recovery.
use the free version...
http://www.killdisk.com/downloadfree.htm
03/03/2010 9:25 AM
You are going the wrong way. Get rid of the LINUX garbage.
Register to Reply 7 comments
Anonymous Poster (1); bwire (2); cwarner7_11 (1); jack of all trades (1); Judge (1); mjb1962853 (1)
