Previous in Forum: CND Engines vs. Bio Gas Engines   Next in Forum: Excess Flow Valve for LPG Truck
Basket Strainer for Mud Pump
03/03/2010 1:27 AM
I NEED TO FRAME UP TECHNICAL CPESIFICATION AND DRAWING FOR FABRICATION OF BASKET STRAINERS FOR MUD PUMP TO BE USED AT WORK OVER RIGS IN THE OIL FIELDS
SUITABLE MEDIUM: BRINE,OIL,GAS, WATER, ORGANIC & IN ORGANIC SOLVENTS LIKE XYLENE FOR WELL STIMULATION ETC.
SOLID TO BE FILTERED OUT: SAND, CEMENT CUTTINGS AND OTHER SOLID DEBRIS FROM THE WELL
PRESSURE: AT INLET 35 PSI (MAX)
MATERIAL OF CONSTRUCTION: CYLINDERICAL HOUSING/OUTER CELL: SS-304/316 ?
INNER PERFORATED CYLIDERICAL STRAINER : SS-304/316 ?
CYLINDERICAL OUTER CELL: DIA- 360 MM, HEIGHT-560 MM THICKNESS- 5MM (MIN)
INNER STRAINER INSERT: DIA-270 MM, HEIGHT- 550 MM, THICKNESS- 5 MM (MIN)
HOLE SIZE: 4-5 MM DIA
SUGGESTION AND SUPPORT FOR FRAMING UP TECH. SPECS AND DRAWING FOR THE SAME
Re: Basket Strainer for Mud Pump
03/04/2010 7:47 AM
Turn off Caps Lock and start getting supplier information and catalogues. Work-up the spec in dialogue with the suppliers.
03/10/2010 7:05 AM
nothing is impossible !
Register to Reply 2 comments
