Previous in Forum: Motorization to Move a Platform   Next in Forum: Slider Crank Mechanism Variations
Oil Filters: In-depth Study Needed
02/01/2007 10:19 AM
I just finished reading the article on oil. While in college 1958 I tested the new just released multigrade oils in the lab and they met all the standards they were rated for.
Now what I would like to see an indepth study of oil filters. We have several brands to purchase but which is the best relative to price.
Pathfinder Tags: oil filters
Re: Oil Filters: In-depth Study Needed
02/01/2007 11:25 AM
The word "best" needs to be qualified.
02/01/2007 7:25 PM
There's some pretty good studies of oil filters (at least from the automotive standpoint) at several of the VW Van sites - water cooled (Vanagon) and the older air cooled (Type 2). Since the both versions of these flat 4 engines are cooling sensitive - much more so for the air cooled - and hold so little oil the use of an incorrect oil filter can have a significant impact on the life of the engine. An incorrect filter many times will either pass through too much oil (and not perform it's filtering task well - longer term problem) or pass through too little oil at starting thereby starving the engine bearings of lubricant for a short space of time (obviously good for engine rebuilders - not good for long term engine life). After doing some net surfing I came upon this site which I hope you will find useful... http://minimopar.knizefamily.net/oilfilterstudy.html
02/02/2007 12:39 AM
CHeck out Lube Talk, Lubetrack newsletter at lubetrak.com, Monday, August 22, 2005, volume 1, issue 205 - Engine oil filter study: http://minimopar.knizefamily.net/oilfilterstudy.html
srive1
02/02/2007 8:36 AM
That is really interesting. Automatically I think of the filter media as being the #1 in regards to what makes a filter "better". It appears that is not all of what makes a good filter. I imagine these faults are in response the outsourcing development and labor to save costs at the expense of quality. Todays CEO doesn't care since after tanking the corporation, he'll take his millions and move on the the next one !
The failing anti-drain valves concern me quite a bit. Most oil pumps will pressurize faster with oil in the filter. No oil means no lubrication and increased engine wear at startup.
I have heard many stories about Fram filters blowing out and Wix cartridge filters coming in slightly "off" sizes. I think Wix "used" to be #1 in many peoples books. Now from what I hear, they are turning to crap.
Register to Reply 4 comments
Anonymous Poster (1); Pretendgineer (1); PWSlack (1); srive1 (1)
