Previous in Forum: Clips for Square Tubes   Next in Forum: steel composiion and its heat treatment
Electroform Stencil - Trapezoidal Hole Standard
03/04/2010 7:20 PM
In IPC 7525, item 4.4.5 trapezoidal apertures, there describes for Chemical etch stencils, the trapezoidal dimension can be specified as 1/2 Z. But for Laser cut and Electroform stencils, there only states "trapezoidal aperature is an inherent part of process. Stencil vendors should be contacted for dimensions."
Any standard for the trapezoidal dimension for Laser cut and Electroform stencils?
Thanks!
Life consists not in holding good cards, but in playing well those you hold. ----J. Billings
Re: Electroform Stencil - Trapezoidal Hole Standard
03/08/2010 4:04 AM
As far as I understand, in laser or electron beam patterning (I assume this is what is refered to by electroform) one uses a mask (stencil) on the laser/electron beam, or even better on the expanded laser/electron beam, and then this beam profile is focussed down and subsequently imaged on your target.
The size of the feature you are etching on the target is thus defined by the optical magnification of the beam rather than the size of the mask.
We are in the business of making light!
03/10/2010 2:09 AM
Thanks GlowStartled!
For Laser and Electric beam, I think you are right for the Trapezoidal.
But the "Electroform Stencil" is not the same as your "Electric beam patterning".
Electroform means the stencil is "Growning" on a film mask by immersing the whole system in electrolyte bath.
Register to Reply 2 comments
