Previous in Forum: earthing of current transformer   Next in Forum: Source of 2MHz impulse noise signal in mains power line???
Controller settings for LTC's
03/06/2010 10:50 PM
What are the appropriate steps used to get the correct settings for the controller of a load tap changer? How is the reactance and resistance settings found?
Re: Controller settings for LTC's
08/02/2010 9:49 AM
Normally, on-load tap changer(OLTC) is controlled automatically by an automatic voltage regulator(AVR) by sensing the secondary voltage. If auto function give trouble secondary voltage could be maintained by two push buttons(up/down) by manually observing the voltage.Further details should be obtained from AVR/OLTC manufacturers.
pnaban
