Previous in Forum: induction motor   Next in Forum: Arc Chute
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Power Engineering - New Member
Primary Side of Delta-Star Transformer
03/07/2010 10:52 AM
is 3O/C+1E/F protection necessary at the primary side of delta-star transformer?
Pathfinder Tags: transformer
Re: electrical engg
03/07/2010 2:39 PM
I think o/c & E/F are necessary @ primary side and secondary side .
Re: electrical engg
03/07/2010 11:41 PM
I think it would depend on what kind of system earthing the delta side or the primary side of the transformer is connected to.
as for me, i would say "yes".. 1 e/f protection would be used to compute the residual currents at the delta side, in which it is unavailable at the high side of the transformer..
Re: electrical engg
04/27/2010 6:12 AM
Sub -- Transformer protection Relay, make ABB, Type – RET 650
We are going to install one no 13.5 MVA, ( Pri . volts -- 11000,& Amps -- 708.6 Sec. volts -- 6600 & Amps – 1181.0 ),power transformer, vector group – yNd11,cooling – ONAN, -- at our cement plant at Meghalaya.
The said transformer will be charge with our own captive generation, i.e. 10.50 MW. Diesel Generator set.
Protection Scheme: ---
Code – 27, 59, 81A, 81B, 81C, 81D, 37, 32, 32A. LFR,
Current Transformer -- 2000/1/1, Qty – 4nos, & 1000/1/1, Qty – 03 nos. in your scope.
You are also requested to send your offer i.e. Price, delivery schedule & technical manual etc. subject to all those protections will be covered as per mentioned above protection including NGR.
Your immediate reply will be highly appreciated per return mail.
Good Answers: 170
Re: Primary Side of Delta-Star Transformer
03/09/2010 8:42 AM
If the delta side is connected to an high impedance grounded source or an ungrounded source, then the E/F relay would serve no useful purpose. If the delta side is connected to a low impedance grounded or solidly grounded source, then, yes! the E/F relay would be meaningful. But, even in such a case, the E/F relay so provided would automatically be an REF Relay and would respond to earth faults on the delta side of the windings only. Any star side earth fault will not be reflected on to the delta side lines.
Register to Reply 4 comments
Anonymous Poster (2); electricalexpert65 (1); hkian (1)
