Previous in Forum: Electrical Engineering`   Next in Forum: HV Line Test
Earthing and Grounding
03/08/2010 12:42 AM
how i can calculate the required no. of copper rods for grounding.
Re: Earthing & Gronding system
03/08/2010 3:00 AM
By experiment. Local ground conditions, not least of which is the height of the local water table, will determine this.
03/08/2010 8:45 AM
last answer a little of the mark.
Size the electrodes according to NEC 250. (The GEC also), then,
It will not be a calculation but a measurement. The NEC states that at 25 ohms between the service and grounding electrode is when you need a second rod on one service. They don't provide any advice if this doesn't solve the problem though!
If it's a SDS, then it will need its own ground rod if put into interactivity with the grid or is placed in operation for a building of any type. If it the equipment is fed or backfeeding service equipment on a separate foundation then the service is located, it will need a grounding electrode. Very general rule: every separate foundation needs an electrode.
Any additional grounding electrodes must be directly bonded to each other.
My answer is a little oversimplified.
Ideally, zero ohms is what you want on the grounding electrode connections. "a low impedance path". Under 5 ohms is a more realistic target.
Use concrete encased electrodes. Ufers. This will improve this performance.
Consult a licensed electrician.
DABRAIN
Register to Reply 2 comments
