I am looking for a smooth surface of seal slots that will be ground in a
rectangular piston. I am trying to get an as fine as possible (lapped quality)
surface perhaps by fine grinding. The material should lend itself for that
need.
I had picked 1330 (or 1320) but can't get it from the local supplier.
C = .28 - .33, Si = .20 - .35, Mn = 1.6 - 1.9, P and S at 0.040,
What alloying element is beneficial for obtaining a smooth, lapped
surface?
Will carbon help? I trust Mn is good, what about Si?
Using Cr, Mo, Ni and such elements will make it costly.
The size is roughly 100 x 100 x 125.
There is some heat involved, internal combustion, cooling is good and
cross-section large.
The stress level is low, hence a low grade steel.
Thanks for your answers.
