Previous in Forum: Earthing Impedance Formula   Next in Forum: Restraing Slope for Differential Relays
Current Transforrmer Connection
03/08/2010 1:46 PM
Dear Friends.
Hope, u all are well and busy in your professional life..
While connecting a CT, the output of secondary is shorted and grounded... but my question is that... are the CTs internally shorted or not????
Regards
Jawwad Siddique
Re: Current Transformer Connection
03/08/2010 1:54 PM
engria;the current transformers are shorted if they are NOT CONNECTED TO AN AMMETER, OR WATT-HOUR METER perry
Re: Current Transforrmer Connection
03/08/2010 4:19 PM
No, CTs are not internally shorted. The outputs are externally shorted for safety reasons to ensure the secondary windings are not accidentally open-circuited when current is passing through the primary (as this creates a very dangerous voltage on the secondary). Once the secondary(s) of the CT are connected to the associated current measurement device then the short is removed. If the short was internal inside the CT then the CT secondary current could never be measured.
Good Answers: 42
03/08/2010 11:13 PM
and then there was the CT that some bloke dropped a wrench on. It became internally shorted! (Caused the motor protection to go south and cost plenty to repair!)
03/09/2010 3:13 PM
if there is current transformer on circuit and if you dont want to use that ct and their secondary, you have to shorted it also grounded then.
it hasn't got any shorted or grounded inside. know so
Selamunaleykum.
Register to Reply 4 comments
GW (1); jack of all trades (1); perry (1); sefaili (1)
