Previous in Forum: ATS Won't Transfer   Next in Forum: Pressure Transducers
Kohler Generator 30RZ82 - Wiring Diagram
03/09/2010 10:29 AM
Can anyone give me a link or wire diagram for a 30RZ82 with a Decision Maker 3?
S# 360470 (Ford 4 cylinder with turbo)
Found generator off in alarm with overcrank light on but starter will not even attempt
to kick in with switch in run position and battery volts up
Good Answers: 213
Re: Kohler Generator 30RZ82 - Wiring Diagram
03/09/2010 10:53 PM
I am not familiar with your particular generator, but my experience with other modern units with electronic controlssuggests that there should be a reset procedure to clear all faults and alarms before you can restart the generator. You should follow this procedure, before trying to bypass the control system...
03/10/2010 11:17 AM
Start with http://www.kohlerpower.com/index.htm or your local dealer. A search for Model 30RZ starts to produce results.
Register to Reply 2 comments
