direct current motor and generator.
if a dc motor refuses to run under load...possible causes could be,, field coils too weak or polarity is not right..if im not mistaken
but off load the motor runs.and full voltage is given by the generator..under load the voltage will drop on the generator, the motor runs a gearbox...could the gearbox be a problem, and why does the voltage drop on the generator..the genny does not arc or anything of the sort....
any information and instruction will be extremely appreciated!
