Previous in Forum: Instrumentation for Desalination Plants   Next in Forum: Manual for Siemens 6DR1520 Process Controller
Pumping Station - Desalination Plant
03/10/2010 6:48 AM
Dear All, I havnt seen practically pumping station (Desalination plant) can any one give clear pictures about pumping and pumping station instrumentation and pumping line field instruments.
Re: Pumping station
03/10/2010 7:03 AM
Re: Pumping Station - Desalination Plant
03/10/2010 9:47 AM
" can any one give clear pictures about pumping"
Here's one:
There are tons more at:www.fotosearch.com/
Hope this helps.
03/10/2010 11:40 AM
Oh, brother... this is the time to ask The Lord above for strenght not to succumb to temptation.
03/11/2010 6:25 AM
Amen!!
Regards
nudnik
03/10/2010 12:53 PM
Dear, As the name indicate , there will be pumps in the pumping station
so there will be a check valve (non-return valve) or a back flow preventor in the system. There can be pipes, fittings connected to various valves to control or regulate the flow. These valves include Butterfly valves, gate valves etc
Coming to the piping line, there will be drain valves, pressure reducing valves and Air valves.......
03/11/2010 7:37 AM
Dear Mr. Sadad,
This is a great time for you and Mr. Imran, he is seven (7) questions back from yours, to sit down together at lunch and discuss the "phylosophy of desalination plants including pumping stations. and Field instruments". I recommend that you do this sooner rather than later as preparing a bid for a project like you are considering is a time consuming process and at this point in the game you are probably not going to be the winner.
Sincerely yours,
Vagabond
vagabond
04/23/2010 12:15 AM
Some practical ideas you may get from my site http://www.pimansoft.com devoted to water treatment and desalination plants design automation. It contains P&IDs for seawater reverse osmosis plant with minimal instrumentation. The paper "Control resolved" explains basic concepts of the plant control.
Devil's in details
Register to Reply 7 comments
Anonymous Poster (1); Loki (1); lyn (1); nudnik (1); pimansoft (1); vagabond (1); Valvemech (1)
