Previous in Forum: Cars with Six-Stroke Engines   Next in Forum: Normal Battery Loads
Air Conditioner Water for Car Battery?
03/11/2010 1:04 AM
Some people say that the water condensed by Air Conditioner is good for Car battery. Is it true?
Re: Air conditioner water for battery use
03/11/2010 5:25 AM
Distilled water? Yes. Be careful how it is stored, though, otherwise its quality and therefore its usefulness will deteriorate.
Good Answers: 60
03/11/2010 3:09 PM
Get the ice from your freezer its quicker.
Re: Air Conditioner Water for Car Battery?
03/12/2010 8:31 AM
The answer to your question is NO.
You should only use distilled water. Distilling water removes impurities and minerals from the water. You to do want minerals to collect on the internal battery plates. This could cause a reduction in battery performance.
If you can't guarantee that all impurities have been removed from the condensed water I wouldn't suggest using it in your battery.
Regards, Tim
Good Answers: 141
03/17/2010 11:17 PM
Batteries need no minerals. If filtered well - because your Ac water - has also dust particles - you can use this. This is called DEMIN water demineralized. It is not so easy available in drugstores that is why Distilled water is used in most cases. It is like using ethyl alcohol to clean. Availability and/ or marketing issue. Only minerals will contaminate your plates.
Plenty of room here
Register to Reply 4 comments
dvmdsc (1); peterg7lyq (1); PWSlack (1); Tim Hawley Master Mech (1)
You might be interested in: Signal Conditioner Chips, Battery Holders
