Previous in Forum: Hydraulics courses   Next in Forum: Motors to Power a Potato Slicer
Pipe Pressure
02/03/2007 5:44 AM
I am having a pipe drawingof 2" OD and 1" ID of length 6". I want to know which material can use for this to with stand pressure of 6000psi.
"Let my body and its pain take care of each other, thou my mind will always be in a bliss"
Pathfinder Tags: materials piping materials
Re: Pipe Pressure
02/03/2007 12:28 PM
reference:
American Welding Society www.aws.org/w/a/
Israel - Member - New Member
Re: Pipe Pressure
02/03/2007 12:44 PM
You can find here
http://www.tube-mac.com/pdf/tubemac_section_a.pdf
and similar sites.
Success to you!
I ask a question? I receive the answer? I react......:)
Re: Pipe Pressure
02/03/2007 4:52 PM
HI. Well, normally it's not the way the design goes, you normally choose a required ID and oper. pressure and then choose an OD from a material that's cheap and easy to manufacture. It seems that you're gonna build an hydraulic actuator, am I right? I'm gonna tell you the formula anyway.;
In any book you're gonna find the furmulae for pipe dimensioning. The simpler is:
Sadm = P x r / t for pipes (tangencial stress), and
Sadm = P x r /2t for pipe end covers (longitudinal stress). In this case, a vector combination is required to obtain the total stress.
where, in si:
Sadm = acceptable tension in material [Pa]
P = internal pressure [Pa]
r = outter radius (the more loaded point of the tube). It's because this simple formula is intended to give you values for thin wall tubes, what is not your case. Anyway, use it as an initial approximation. You will be forced to enter a good safety margin anyway...
t = tube thickness.
Using consistent units in this formula, you'll be able to obtain the stress required for your application geometry. DOn't forget to dimension to twice the operational pressure, for safety, stiffness, and because that's the way it should be if you refer to any standard.
For the numbers you posted, the stress will be
6000 psi approx 41,37 MPa
2 in = ,0508 m
1 in = ,0254 m
Sadm = 82.74 MPa
If you consider the double, You'll have approx. 165 MPa min yeld stress in your material. For these numbers, a low carbon steel in a cold drawn condition (Sy=approx. 200 - 250 MPa) will sufice. Note that low carbon steel normalized (Sy=125 MPa approx.) will not be enough if you consider the safety margin. You have a lot of material in that 1" wall X 1" ID
Also: If it's an actuator, don't forget to add the mechanical stresses in work with the internal pressure values.
Humm... suspicious you are...
Re: Pipe Pressure
02/04/2007 12:38 AM
Thanks a Lot. I got a use full Information from Cr4 people.
Re: Pipe Pressure
02/05/2007 11:52 AM
a Pipe with a 2" OD, and 1" ID only has a 1/2" wall
Re: Pipe Pressure
02/05/2007 12:07 PM
Very well observed. I think I missed it thinking about 1" wall.
So, you're gonna need 160 MPA admissible, 320 MPa max stress in material.
Did you consider the remaining mechanical loads in it?
You still may need a cold drawn steel around 300 MPa yeld strengh, or, if the remaining mecahnical loads are to be considered, go for a low alloy steel. I think an SAE 1045 would do well.
Register to Reply 6 comments
Anonymous Poster (2); bhrescobar (2); vdik (1); y eye (1)
