Previous in Forum: Mr.   Next in Forum: Wooden water tank
17 comments
bouyancy
03/13/2010 7:59 AM
What is the bouyancy in ounces or pounds , of a sealed pvc pipe 36" x 3" dia. ( at sea level, on the surface)?
Same for a 2"x 36".
Thank you,
nm
Re: buoyancy
03/13/2010 8:12 AM
  1. Calculate enclosed volume (= pi x r2 x l, where r is radius of pipe, l is length).
  2. Calculate weight of that volume of seawater (= volume x density).
To a first approximation, the result is the buoyancy.
Good Answers: 143
Re: bouyancy
03/13/2010 9:09 AM
If it's on the surface (I assume you mean floating), the buoyancy equals the weight.
Re: bouyancy
03/13/2010 9:27 AM
What I am trying to figure is how much steel weight will these sizes of a closed system , support at the surface without sinking.
3x36 would float "?" of steel weight.
Thank you.
Good Answers: 143
Re: bouyancy
03/13/2010 9:34 AM
Take the enclosed volume. Multiply that by the weight density of the water you're gonna put this in. Subtract the PVC weight. That's your answer.
Good Answers: 143
Re: bouyancy
03/13/2010 11:14 AM
D'oh. Take the TOTAL volume, not just enclosed.
Re: buoyancy
03/13/2010 11:23 AM
You're right, but I don't think a little bit of PVC's going to make much difference either way (in this context).
Good Answers: 143
Re: buoyancy
03/13/2010 11:35 AM
Yep, it's close enough to water that it's not a big deal. I just thought I should pick on my answer as much as I pick on others. 'Course, I'm closer to the dumb, so I see it easier.
Good Answers: 137
Re: buoyancy
03/15/2010 11:53 AM
Hello TVP45 - it's not the weight compared with water that matters, it's the weight compared with air. SG of PVC is about 1.1, and with a few assumptions I make the weight of each float about 4.5 lb. That needs to be subtracted to get the net (pun intended!) buoyancy.
Cheers..........Codey
Re: buoyancy
03/15/2010 12:18 PM
Sounds kinda heavy - what wall thickness did you take?
Good Answers: 137
Re: buoyancy
03/15/2010 12:44 PM
8 mm (5/16")
Re: buoyancy
03/15/2010 12:57 PM
Ah! I was thinking more of 2.5 - 3mm. Wonder if netmaker's still around? I'd better pm him to try to get the facts straight.
Good Answers: 143
Re: buoyancy
03/15/2010 1:53 PM
Eureka! I think it's water, but I'm open to convincing. Why do you think air?
Good Answers: 137
Re: buoyancy
03/16/2010 11:42 AM
As you said in #4 and 9, it's the total volume that determines water displaced, hence the upthrust. But if you just use that, it's like assuming the pipe is of zero wall thickness (or zero wall material density). Need to subtract weight of the pipe (in air) to get net upthrust.
If the pipe were solid, total volume = material volume. If you just subtract the apparent weight in water from the gross you get net upthrust 90% of gross (for SG 1.1) but actual net upthrust is negative (or in simple terms, it sinks!)
There's probably a neater explanation, but that's all I can think of at the minute.
Cheers......Codey
Re: bouyancy
03/13/2010 9:35 AM
Build a pipe capped only at one end. Go to the ocean. Begin to add weight until the tube sinks vertically below the surface to the desired level.
That's your number.
Re: bouyancy
03/13/2010 10:05 AM
I have a 35 lb. steel weight that has to be bouyed just under the surface in sea water.
I can not use more than 36" in length.
How many 3" diameter x 36" lengths do I need to keep the weight supported?
Nothing exact , just a close approx. of how many sections.
Re: buoyancy
03/13/2010 10:27 AM
OK, for one length,
V = pi x r2 x l
= 3.14 x 1.5 x 1.5 x 36 cubic inches
≈ 255 in3
Density of seawater ≈ 64 lb/ft3 [1] ≈ 0.037 lb/in3
So each pipe can support about 255 x 0.037 = just under 9½ lb.
So a 35 lb steel weight would sink with 3 lengths, and float with 4.
[1] I looked up this figure, but didn't check it.
Re: buoyancy
03/13/2010 10:34 AM
That's what I needed. 4 lengths is the number.
Thank you.
nm
Register to Reply 17 comments
Codemaster (3); JohnDG (5); lyn (1); netmaker (3); TVP45 (5)
