Previous in Forum: narelmr   Next in Forum: pumps
narelmr alum pole
03/13/2010 10:39 AM
what is bending strength of 6063-t5 round pipe with 1/8'' wall
Pathfinder Tags: narelmr alum pole
Good Answers: 143
Re: narelmr alum pole
03/13/2010 2:12 PM
What do you mean by bending strength, what are the dimensions of the pipe, and how is the pipe supported and loaded?
03/13/2010 3:07 PM
4'' diameter used for a pylon sign under 90 mph (18psf) wind load- 4' high x 3.5' wide
bottom of sign 7' above grade
Good Answers: 29
03/13/2010 7:20 PM
According to my AASHTO design tables there is no 48' by 42" standard sign. However; both a 48" by 48" and a 48" by 36" sign require a 4" diameter by 1/4" wall thickness aluminum pole with a 2' wide by 4' deep concrete foundation. A sign of this type also requires a break away connection at ground level.
Si vis pacem, para bellum
03/14/2010 9:29 AM
there are signs of all sizes. just depends on what customer wants to pay. so, this sign is 48'' high by 42'' wide and is 7' off the ground. the footer is an augered type and is 2' in diameter
Good Answers: 29
03/14/2010 11:02 AM
Nonetheless; for 90 mile per hour wind load, what I stated before is what the American Association of State Highway and Transportation Officials sign design tables recommends.
narelmr (2); PMoon (2); TVP45 (1)
