Previous in Forum: how many choices are there?   Next in Forum: Psychic Engineers...
What Material is the electromagnet on a cathoray tube
03/13/2010 5:39 PM
Can any body tell me the material that the electromagnet on a cathode ray tube is made from. and how would you be able to cut this substance. Would this method of cutting also apply to cutting up permanent magnets.
Thank you all.
Re: What Material is the electromagnet on a cathoray tube
03/13/2010 10:12 PM
I assume you are talking about the ceramic like ferrite material that is used around the neck of the CRT.
Being its rather brittle it can cut and shaped with a grinding disk like you would a ceramic tile.
Most magnets can be cut or ground similarly as well. But some types create a rather toxic and flamible dust so they should be wet ground or cut.
03/15/2010 4:41 AM
Regards.
A good answer but it is not a permanet magnet [Yoke as said by another poster] but A SOFT Magnatic material having almost zero residual magnetism; Shape moulded in a die, no need to ground.
For deflection coils & Hi-Freq Signal & Power transformers & coils; well above 2MHz
Location: West Point, Texas population around 200.Located between Austin and Houston
03/13/2010 11:57 PM
This is called the YOKE,,that is copper wound on ferrite forms,,and can with proper patience and tools be slipped off the CRT.
Joe in Texas
We hold these truths to be self evident,one nation under God
Good Answers: 141
03/14/2010 10:44 PM
As mentioned by the other posters, the material is ferrite. It is normally only magnetized with the current. There might be some remanent magnetism in it but it doesn't have to be there. It is very brittle. With a diamond disc (e,g mini tool grinder) it cuts. You can also crack it, and it can fall to pieces when hammered. Same with ferrite magnets, samarium cobalt, strontium cobalt. Alnico magnets need machining. When splitting magnets, you make new small ones out of the pieces. Be careful - splinters can be awfully sharp.
Plenty of room here
03/15/2010 12:06 AM
water jet cut , also , can cut it
devitg
Good Answers: 109
03/15/2010 4:25 AM
Hi,
ferrite -as any other ceramic material- is usually cut by circular diamond-coated blades.
If you have complicated shapes there is a wire saw (using diamond coated wire) with NC control available.
Ultrasonic cutting is used for thin sections or mass production.
Cracking and gluing again is sometimes useful.
RHABE
03/15/2010 6:48 AM
Recycling?
If not that, just out of curiosity, why would you want to cut it?
Wangito.
Never trade luck for skill.
devitg (1); dvmdsc (1); Haajee (1); Judge (1); RHABE (1); tcmtech (1); wangito (1)
You might be interested in: Cutting Services
