Question for discussion; If you are to look at a Hvac system that holds 12#'s of 410A and you determine by all readings taken that the system has lost some of its charge and is not cooling properly and you investigate and find a leaky seal at the brass fitting on the indoor Txv that was not tightened down completely and you make the repair.
Now, lets say it is 2#'s low of refrigerant. Can the method as used in years past with R-22, such as since there was no lines open to air with there being plenty of pressure to keep air out, work with this 410A refrigerant by just topping off the charge with subcool and etc? Or since the 410A is made up of several different refrigerants can you just top it off or should you always reclaim and pull deep vacuum and then weigh in charge?
If the latter of the two is correct, we are screwed with the shade tree type of guys out there doing the first way mentioned and beating us out of a lot of jobs.
Thanks in advance for all comments. I hope to use the knowledge gained, in an up coming service meeting.
Yes, I know there are a lot of things in a real problem to look at, than just the the ones listed above, I am only trying to make a reference so you could see where I am coming from on the question of 410A.
Thanks.
