We are building a new race engine to race with 1000 cc mini sprints.
The engine is a 4 cylinder in-line dual overhead cam design. What we wish to do is change the fireing order (now 1-2-4-3) to 1&4 at the same time then 180 degrees and then 2&3 then 360 degrees and back to 1&2. This is called a big bang motor and because of the power pusles being un even helps traction on slick dirt which we spend a lot of time racing on.
To achieve this one must cut the cam shafts between# 2 and #3 cylinders and rotate them 180 degrees.
The cam's are made of some sort of cast steel. they have a 5/8" hole bored in the middle to carry lube to the lobes and jurnals. If we machine a piece of 5/8" chrome moly tube 4130n and press in the two cam halves then v and weld back with tig welder and nickel rod, could we expect any sort of life out of these cams?
We have an old head that we would use to set up cam in and as a welding jig.
Thanks Bill
Dad's Muffler Racing
